[Swift-devel] compilation problems with the latest swift package
    Wenjun Wu
    wwj at ci.uchicago.edu
    Mon Feb 22 11:50:02 CST 2010
Hi Mihael,
  Are you suggesting that I should use JDK1.5 to compile the swift package?
  Actually I'm using JDK1.5 and Ant 1.6.5. But I still got the same problem.
  Is there any other things I should try to make it work?
Wenjun
> Hi Wenjun,
> We switched to java 1.5 with the trunk version of swift and cog.
> The stable branch (details on the download page), which I would
> recommend for you, is still made for 1.4.
> Mihael
> On Wed, 2010-02-17 at 11:56 -0600, Wenjun Wu wrote:
>> Hello,
>>   I tried to compiled the latest swift package from the swift svn and
>> got some errors.
>>   The version info for the package is
>> svn info
>> Path: .
>> URL: https://svn.ci.uchicago.edu/svn/vdl2/trunk
>> Repository Root: https://svn.ci.uchicago.edu/svn/vdl2
>> Repository UUID: e2bb083e-7f23-0410-b3a8-8253ac9ef6d8
>> Revision: 3238
>> Node Kind: directory
>> Schedule: normal
>> Last Changed Author: wozniak
>> Last Changed Rev: 3237
>> Last Changed Date: 2010-02-12 15:32:49 -0500 (Fri, 12 Feb 2010)
>>  Could anyone give any suggestions for fixing the problem?
>>   Thanks,
>> Wenjun
>>   compile:
>>      [echo] [provider-coaster]: COMPILE
>>     [javac] /root/swift/cog/mbuild.xml:228: warning: 'includeantruntime'
>> was not set, defaulting to build.sysclasspath=last; set to false for
>> repeatable builds
>>     [javac] Compiling 6 source files to
>> /root/swift/cog/modules/provider-coaster/build
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/CoGResourceIOProvider.java:88:
>> cannot find symbol
>>     [javac] symbol  : constructor
>> IOException(java.lang.InterruptedException)
>>     [javac] location: class java.io.IOException
>>     [javac]                 throw new IOException(e);
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/CoGResourceIOProvider.java:132:
>> cannot find symbol
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/LocalCopyIOProvider.java:72:
>> cannot find symbol
>>     [javac] symbol  : constructor IOException(java.net.URISyntaxException)
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/LocalIOProvider.java:91:
>> cannot find symbol
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/LocalIOProvider.java:135:
>> cannot find symbol
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/ProxyIOProvider.java:84:
>> cannot find symbol
>>     [javac] symbol  : constructor IOException(java.lang.Exception)
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/ProxyIOProvider.java:205:
>> cannot find symbol
>> IOException(java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelException)
>>     [javac]                 throw new IOException("Cannot establish
>> channel to " + uri.getHost(), e);
>>     [javac]                       ^
>>     [javac]
>> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/ProxyIOProvider.java:221:
>> cannot find symbol
>> IOException(java.lang.String,org.globus.cog.karajan.workflow.service.ProtocolException)
>>     [javac]                 throw new IOException("Error requesting file
>> from " + channel, e);
>>     [javac]                       ^
>>     [javac] 8 errors
>> BUILD FAILED
>> /root/swift/cog/modules/swift/build.xml:73: The following error occurred
>> while executing this line:
>> /root/swift/cog/mbuild.xml:444: The following error occurred while
>> /root/swift/cog/mbuild.xml:79: The following error occurred while
>> /root/swift/cog/mbuild.xml:52: The following error occurred while
>> /root/swift/cog/modules/swift/dependencies.xml:13: The following error
>> occurred while executing this line:
>> /root/swift/cog/mbuild.xml:163: The following error occurred while
>> /root/swift/cog/mbuild.xml:168: The following error occurred while
>> /root/swift/cog/modules/provider-coaster/build.xml:59: The following
>> error occurred while executing this line:
>> /root/swift/cog/mbuild.xml:465: The following error occurred while
>> /root/swift/cog/mbuild.xml:228: Compile failed; see the compiler error
>> output for details.
>> Total time: 16 seconds
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
