[Swift-devel] compilation problems with the latest swift package
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Feb 17 12:01:20 CST 2010
Hi Wenjun,
We switched to java 1.5 with the trunk version of swift and cog.
The stable branch (details on the download page), which I would
recommend for you, is still made for 1.4.
Mihael
On Wed, 2010-02-17 at 11:56 -0600, Wenjun Wu wrote:
> Hello,
>   I tried to compiled the latest swift package from the swift svn and
> got some errors.
>   The version info for the package is
> svn info
> Path: .
> URL: https://svn.ci.uchicago.edu/svn/vdl2/trunk
> Repository Root: https://svn.ci.uchicago.edu/svn/vdl2
> Repository UUID: e2bb083e-7f23-0410-b3a8-8253ac9ef6d8
> Revision: 3238
> Node Kind: directory
> Schedule: normal
> Last Changed Author: wozniak
> Last Changed Rev: 3237
> Last Changed Date: 2010-02-12 15:32:49 -0500 (Fri, 12 Feb 2010)
>  Could anyone give any suggestions for fixing the problem?
>   Thanks,
> Wenjun
>   compile:
>      [echo] [provider-coaster]: COMPILE
>     [javac] /root/swift/cog/mbuild.xml:228: warning: 'includeantruntime'
> was not set, defaulting to build.sysclasspath=last; set to false for
> repeatable builds
>     [javac] Compiling 6 source files to
> /root/swift/cog/modules/provider-coaster/build
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/CoGResourceIOProvider.java:88:
> cannot find symbol
>     [javac] symbol  : constructor
> IOException(java.lang.InterruptedException)
>     [javac] location: class java.io.IOException
>     [javac]                 throw new IOException(e);
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/CoGResourceIOProvider.java:132:
> cannot find symbol
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/LocalCopyIOProvider.java:72:
> cannot find symbol
>     [javac] symbol  : constructor IOException(java.net.URISyntaxException)
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/LocalIOProvider.java:91:
> cannot find symbol
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/LocalIOProvider.java:135:
> cannot find symbol
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/ProxyIOProvider.java:84:
> cannot find symbol
>     [javac] symbol  : constructor IOException(java.lang.Exception)
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/ProxyIOProvider.java:205:
> cannot find symbol
> IOException(java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelException)
>     [javac]                 throw new IOException("Cannot establish
> channel to " + uri.getHost(), e);
>     [javac]                       ^
>     [javac]
> /root/swift/cog/modules/provider-coaster/src/org/globus/cog/abstraction/impl/file/coaster/handlers/providers/ProxyIOProvider.java:221:
> cannot find symbol
> IOException(java.lang.String,org.globus.cog.karajan.workflow.service.ProtocolException)
>     [javac]                 throw new IOException("Error requesting file
> from " + channel, e);
>     [javac]                       ^
>     [javac] 8 errors
> BUILD FAILED
> /root/swift/cog/modules/swift/build.xml:73: The following error occurred
> while executing this line:
> /root/swift/cog/mbuild.xml:444: The following error occurred while
> /root/swift/cog/mbuild.xml:79: The following error occurred while
> /root/swift/cog/mbuild.xml:52: The following error occurred while
> /root/swift/cog/modules/swift/dependencies.xml:13: The following error
> occurred while executing this line:
> /root/swift/cog/mbuild.xml:163: The following error occurred while
> /root/swift/cog/mbuild.xml:168: The following error occurred while
> /root/swift/cog/modules/provider-coaster/build.xml:59: The following
> error occurred while executing this line:
> /root/swift/cog/mbuild.xml:465: The following error occurred while
> /root/swift/cog/mbuild.xml:228: Compile failed; see the compiler error
> output for details.
> Total time: 16 seconds
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
