[Swift-devel] Problem with iterate
Ioan Raicu
iraicu at cs.uchicago.edu
Fri Feb 19 14:09:25 CST 2010
Oops, I sent it again from the wrong account.
Ioan Raicu wrote:
> Yes, I think my confusion is coming from the fact that the order of
> statement in the source code is not preserved in the execution order
> (assuming there are dependencies). You are saying that the order in
> the source code doesn't matter in Swift. Perhaps this is what is
> making the analysis harder, to detect these deadlocks? If Swift
> insisted on an ordering in execution, relative to the source code
> ordering, perhaps the analysis would be simplified?
> My curiosity is mostly driven by trying to understand what assumptions
> in Swift is making this analysis hard to do, and how you would do
> things differently to help this kind of analysis be easier to do? BTW,
> I have a student in my class that is interested automated
> parallelization of code, so this conversation is highly relevant for
> his project (and my understanding).
> Thanks for all the explanations!!!
> Ioan
> Ioan Raicu, Ph.D.
> NSF/CRA Computing Innovation Fellow
> Center for Ultra-scale Computing and Information Security (CUCIS)
> Department of Electrical Engineering and Computer Science
> Northwestern University
> 2145 Sheridan Rd, Tech M384
> Evanston, IL 60208-3118
> Cel: 1-847-722-0876
> Tel: 1-847-491-8163
> Email: iraicu at eecs.northwestern.edu
> Web: http://www.eecs.northwestern.edu/~iraicu/
> https://wiki.cucis.eecs.northwestern.edu/
> Mihael Hategan wrote:
>> On Fri, 2010-02-19 at 12:28 -0600, Ioan Raicu wrote:
>>> If you preserve the order of statements, statement 1 and 2 would get
>>> done first, in parallel if enough resources were available.
>> How would you know the value of a[2] without the complex function in
>> statement 3 being evaluated?
>>> However, statement 3 could not be evaluated until the complex
>>> function runs, at which time it can be added to the DAG and executed.
>>> This implies that you don't need a complete DAG in order to execute
>>> the DAG. In other words, start building the DAG as much as you can
>>> with static information, but also start executing the DAG as soon as
>>> there is anything in the DAG.
>> This is how swift works.
>> But then it's also the thing preventing you from checking the (not yet
>> fully built) dag at compile time.
>>> This would not work if you had to build the entire DAG apriori to
>>> starting to execute it, due to the dynamic nature of the data
>>> dependency.
>>> So, your question about what should happen here, is that at run time
>>> you figure out the value of the complex function, and execute the
>>> statement accordingly. In the end, a[2] will have the same value as
>>> a[0] or a[1]. In theory, I don't see why this example would have to
>>> deadlock.
>> Because if the complex function returns 1, then the program is the same
>> as (and forgive me for forgetting the dummy function, "+" in our case):
>> a[1] = a[2] + 1;
>> a[2] = a[1] + 1;
>>> Also, I don't think the order of the statements should be changed,
>>> for example moving statement statement 3 up and statement 2 down,
>>> preventing the a[2] overwrite.
>> There is some fundamental misunderstanding here. There is no overwrite.
>> It's probably not useful to continue the discussion if you insist on its
>> existence. The confusion is probably up there with the "order of
>> execution of statements". There is no difference between any of the
>> permutations of the statements in that program. They all mean the same
>> thing. Assignment happens not when a statement is encountered in the
>> source code but when the value on the right is available. So in the case
>> of:
>> a = 0;
>> b = a + 1;
>> c = b + 1;
>> a = 0 happens at t0 (all constants are available at t0)
>> b = 1 happens at t0 + 1
>> c = 2 happens at t0 + 2
>> The exact same would happen if you wrote:
>> c = b + 1;
>> b = a + 1;
>> a = 0;
>> or
>> c = b + 1
>> a = 0
>> b = a + 1
Ioan Raicu, Ph.D.
Cel: 1-847-722-0876
Tel: 1-847-491-8163
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100219/68803d27/attachment.html>
