[Swift-devel] Problem with iterate
Mihael Hategan hategan at mcs.anl.gov
Fri Feb 19 12:58:56 CST 2010
On Fri, 2010-02-19 at 12:28 -0600, Ioan Raicu wrote:
> If you preserve the order of statements, statement 1 and 2 would get
> done first, in parallel if enough resources were available.
How would you know the value of a[2] without the complex function in
statement 3 being evaluated?
>  However, statement 3 could not be evaluated until the complex
> function runs, at which time it can be added to the DAG and executed.
> This implies that you don't need a complete DAG in order to execute
> the DAG. In other words, start building the DAG as much as you can
> with static information, but also start executing the DAG as soon as
> there is anything in the DAG.
This is how swift works.
But then it's also the thing preventing you from checking the (not yet
fully built) dag at compile time.
>  This would not work if you had to build the entire DAG apriori to
> starting to execute it, due to the dynamic nature of the data
> dependency.
> So, your question about what should happen here, is that at run time
> you figure out the value of the complex function, and execute the
> statement accordingly. In the end, a[2] will have the same value as
> a[0] or a[1]. In theory, I don't see why this example would have to
> deadlock.
Because if the complex function returns 1, then the program is the same
as (and forgive me for forgetting the dummy function, "+" in our case):
a[1] = a[2] + 1;
a[2] = a[1] + 1;
>  Also, I don't think the order of the statements should be changed,
> for example moving statement statement 3 up and statement 2 down,
> preventing the a[2] overwrite.
There is some fundamental misunderstanding here. There is no overwrite.
It's probably not useful to continue the discussion if you insist on its
existence. The confusion is probably up there with the "order of
execution of statements". There is no difference between any of the
permutations of the statements in that program. They all mean the same
thing. Assignment happens not when a statement is encountered in the
source code but when the value on the right is available. So in the case
of:
a = 0;
b = a + 1;
c = b + 1;
a = 0 happens at t0 (all constants are available at t0)
b = 1 happens at t0 + 1
c = 2 happens at t0 + 2
The exact same would happen if you wrote:
c = b + 1;
b = a + 1;
a = 0;
or
c = b + 1
a = 0
b = a + 1
