[Swift-devel] Problem with iterate
Ben Clifford benc at hawaga.org.uk
Fri Feb 19 11:54:28 CST 2010
A point of information related to this discussion:
Underordered single assignment doesn't necessarily lead to deadlock in
general. Using Haskell, and making this mutually recursive definition of x
and y.
f l = 1 : l     -- if you like lisp,  1:l means (cons 1 l)
x = f y
y = f x
main = print x
x and y are both infinite lists [1,1,1,1,1,1,1,1,1,1,1,1,1,...] (so
running the above code prints out a never-ending (until ctrl-c) list of
1,1,1,1,...)
Also in Haskell, if you substitute in this,
f l = if length l < 200 then 1 : l else l
then Haskell detects a loop at runtime (not compile time) - that's pretty
much the kind of "deadlock detection" that we're talking about here.
$ ./example2
example2: <<loop>>
(or indeed anything involving the use of 'length l' I think)
It might be reasonable to not attempt to do something in this space if ghc
cannot do it.
Now whats different between the above example and swiftscript? well, I
used lists which is a data type that Swift doesn't have. Though maybe its
possible to make something like this using arrays/structs somehow.
http://www.hawaga.org.uk/ben/
