[Swift-devel] Problem with iterate
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Feb 19 11:41:37 CST 2010
Mihael Hategan wrote:
> On Fri, 2010-02-19 at 10:59 -0600, Ioan Raicu wrote:
>> But lets bring this back to a more real example. A user wanting to
>> express some computations that have some dependencies, would write out
>> their computations in some order, expecting their order to be
>> preserved because of the dependencies. If you only support single
>> assignment on variables (e.g. the data), then an example like the one
>> below could never deadlock because the single assignment would be
>> violated on the 2nd statement. Perhaps things are more complicated if
>> you support multiple assignments per variables, but that is not the
>> case for Swift, right?
> x = y + 1
> y = x + 1
> How many assignments are there? 2
> How many variables are being assigned? 2
> Do those assignments have the same lvalue (thing on the left)? no
> Conclusion: each variable is assigned exactly once.
However, y and x have to be defined somewhere, right? If they don't get
their value assigned at definition time, then the statement x = y + 1
should return with an error that y is not defined.
>> I am trying to understand if this deadlock is happening in Swift due
>> to some particular implementation detail in Swift (or underlying
>> pieces), or is it a fundamental flaw in the DAG based approach with
>> single assignment variables? Or is it due to something completely
>> different?
> It seems to be a fundamental flaw with computers and algorithms.
Ioan Raicu, Ph.D.
NSF/CRA Computing Innovation Fellow
Center for Ultra-scale Computing and Information Security (CUCIS)
Department of Electrical Engineering and Computer Science
Northwestern University
2145 Sheridan Rd, Tech M384
Evanston, IL 60208-3118
Cel:   1-847-722-0876
Tel:   1-847-491-8163
Email: iraicu at eecs.northwestern.edu
Web:   http://www.eecs.northwestern.edu/~iraicu/
       https://wiki.cucis.eecs.northwestern.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100219/b76d86f3/attachment.html>
