[Swift-devel] Re: Running the GO Swift prototype
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Dec 15 18:10:43 CST 2010
Hi Allan,
This is at least partial good news, and nice progress.
First step we can try on scaling (maybe easy, maybe not) is to cut down on external processes. I'll take a quick look and see if I can spot another strategy.
The obvious strategy would be to bite the bullet and move to a true provider, that can keep a huge number of requests pending without consuming heavy resources.
I'm fearful that external.sh needs to be synchronous, but maybe we can use a slightly different interface to separate the requests from the notifications.
- Mike
----- Original Message -----
> Hi Mike,
> I got the basic functionality working from your sample external.sh
> scripts. I was able to synthesize a workload of 200 transfers. I'll
> send you and raj about that in another email.
> The basic scripts starts to break at 3000 transfers. I set my number
> of files to 10k and foreach.maxthread to 3000 . I guess at this
> point, external.sh already create too much files at a time for the
> ready queue to handle. The number of processes forked is probably too
> much as well. communicado is already crawling at this point. Even
> though Swift already reported 3000 files staged in. The logs in
> external.sh only reported 758 transfers initiated to globus online.
> A CDM external handler will probably blow-up in general as it will
> fork a process / shellscript for each transfer. If foreach is set to
> 10000, we can't scale.
> I guess a more scalable solution for swift is to make a native call
> (karajan/java) to a queueing service (something like Stork in condor)
> for data transfer.
> -Allan
> 2010/12/13 Michael Wilde <wilde at mcs.anl.gov>:
> > Allan, the code is on PADS login1 under /scratch and seems to work.
> > You will need to look into the swift/src/trunk.gomods src tree to
> > see what I changed in there. Some but perhaps not all the diffs in
> > that tree are for supporting globus online.
> > Let me know if you can replicate the example test below.
> > Justin, it would be good if we can integrate the mods for this into
> > trunk in some non-invasive way as way to share these tests, even if
> > we do it as a separate vdl-int.GO.k that the user/experimenter needs
> > to manually copy to vdl-int.k
> > Or I guess we could put them in an experimental branch?
> > - Mike
> > 1 ) gorunner.sh >& gorunner.out
> > 2 )
> > PATH=/scratch/local/wilde/swift/src/trunk.gomods/cog/modules/swift/dist/swift-svn/bin:$PATH
> > 3 ) swift -config cf -tc.file tc.data -sites.file sites.xml
> > -cdm.file fs.ftponly gcat2.swift
> > Thats it.
> > In gorunner.out, should see:
> > ./gorunner.sh: joblist is empty
> > ./gorunner.sh: joblist is:
> > cp-yuptfz2k.job.in
> > ./gorunner.sh: started transfer task
> > 4dfe903e-06f7-11e0-aa30-1231350018b1
> > /home/wilde/swift/lab/go/gowaiter.sh: waiting on
> > 4dfe903e-06f7-11e0-aa30-1231350018b1 has completed
> > /home/wilde/swift/lab/go/gowaiter.sh: marked cp-yuptfz2k.job.in
> > transferred
> > On swift stdout/err should see:
> > login1$ swift -config cf -tc.file tc.data -sites.file sites.xml
> > CDM file: fs.ftponly
> > Swift svn swift-r3707 (swift modified locally) cog-r2932 (cog
> > modified locally)
> > RunID: 20101213-1426-dff3my97
> > Progress:
> > /home/wilde/swift/lab/go/external.sh: running in
> > Progress: Submitting:1
> > in /home/wilde/swift/lab/go/cp.sh:
> > wd=/home/wilde/swift/lab/go/work/gcat2-20101213-1426-dff3my97/jobs/y/cp-yuptfz2k
> > arg1=etc/group arg2=output/plainoutput.txt
> > in /home/wilde/swift/lab/go/cp.sh: rc=0
> > Progress: Checking status:1
> > Final status: Finished successfully:1
> > login1$
> > Thats it.
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
