[Swift-devel] Re: Running the GO Swift prototype
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Wed Dec 15 17:59:56 CST 2010
Hi Mike,
I got the basic functionality working from your sample external.sh
scripts.  I was able to synthesize a workload of 200 transfers.  I'll
send you and raj about that in another email.
The basic scripts starts to break at 3000 transfers.  I set my number
of files to 10k and foreach.maxthread to 3000 .  I guess at this
point, external.sh already create too much files at a time for the
ready queue to handle.  The number of processes forked is probably too
much as well.  communicado is already crawling at this  point.  Even
though Swift already reported 3000 files staged in. The logs in
external.sh only reported 758 transfers initiated to globus online.
A CDM external handler will probably blow-up in general as it will
fork a process / shellscript for each transfer.  If foreach is set to
10000, we can't scale.
I guess a more scalable solution for swift is to make a native call
(karajan/java) to a queueing service (something like Stork in condor)
for data transfer.
-Allan
2010/12/13 Michael Wilde <wilde at mcs.anl.gov>:
> Allan, the code is on PADS login1 under /scratch and seems to work.
> You will need to look into the swift/src/trunk.gomods src tree to see what I changed in there.  Some but perhaps not all the diffs in that tree are for supporting globus online.
> Let me know if you can replicate the example test below.
> Justin, it would be good if we can integrate the mods for this into trunk in some non-invasive way as way to share these tests, even if we do it as a separate vdl-int.GO.k that the user/experimenter needs to manually copy to vdl-int.k
> Or I guess we could put them in an experimental branch?
> - Mike
> 1 ) gorunner.sh >& gorunner.out
> 2 ) PATH=/scratch/local/wilde/swift/src/trunk.gomods/cog/modules/swift/dist/swift-svn/bin:$PATH
> 3 ) swift -config cf -tc.file tc.data -sites.file sites.xml -cdm.file fs.ftponly gcat2.swift
> Thats it.
> In gorunner.out, should see:
> ./gorunner.sh: joblist is empty
> ./gorunner.sh: joblist is:
> cp-yuptfz2k.job.in
> ./gorunner.sh: started transfer task 4dfe903e-06f7-11e0-aa30-1231350018b1
> /home/wilde/swift/lab/go/gowaiter.sh: waiting on 4dfe903e-06f7-11e0-aa30-1231350018b1
> /home/wilde/swift/lab/go/gowaiter.sh: 4dfe903e-06f7-11e0-aa30-1231350018b1 has completed
> /home/wilde/swift/lab/go/gowaiter.sh: marked cp-yuptfz2k.job.in transferred
> On swift stdout/err should see:
> login1$ swift -config cf -tc.file tc.data -sites.file sites.xml -cdm.file fs.ftponly gcat2.swift
> CDM file: fs.ftponly
> Swift svn swift-r3707 (swift modified locally) cog-r2932 (cog modified locally)
> RunID: 20101213-1426-dff3my97
> Progress:
> /home/wilde/swift/lab/go/external.sh: running in /home/wilde/swift/lab/go
> Progress:  Submitting:1
> in /home/wilde/swift/lab/go/cp.sh: wd=/home/wilde/swift/lab/go/work/gcat2-20101213-1426-dff3my97/jobs/y/cp-yuptfz2k arg1=etc/group arg2=output/plainoutput.txt
> in /home/wilde/swift/lab/go/cp.sh: rc=0
> Progress:  Checking status:1
> Final status:  Finished successfully:1
> login1$
> Thats it.
