[Swift-devel] Provider staging is failing
wilde at mcs.anl.gov wilde at mcs.anl.gov
Mon Aug 30 23:07:34 CDT 2010
----- "Justin M Wozniak" <wozniak at mcs.anl.gov> wrote:
> I think that's ok.
Right: Mihael pointed out to me in IM that the exec'ed program is /bin/bash with _swiftwrap.staging as an arg.
Digging deeper it looks like _swiftwrap.staging is getting run with this command line:
/bin/bash _swiftwrap.staging -e /bin/cat -out outdir/f.0001.out -err stderr.txt -i -d '|outdir' -if data.txt -of outdir/f.0001.out -k -cdmfile  -status provider -a data.txt
and the extra "|" separator in the -d 'outdir' arg (quotes mine) is causing a spurious mkdir to get invoked for what would have been the "in dirs" argument.That in turn is causing the ret code 254.
I think that extra | separator is not supposed to be there when there are no input directories (as in this case). vdl-int.staging has:
  "-d", flatten(each(fileDirs)),
and I now suspect a null value for the dirs of stagein is not being handled right, somewhere around:
   fileDirs := fileDirs(stagein, stageout)
- Mike
> Do you have the wrapper.log/info files?
> On Mon, 30 Aug 2010, Michael Wilde wrote:
> > _swiftwrap.staging didnt sem to get marked executable:
> > ----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
> >> WIth proxy the stageins seem to complete. Then a get a 254 when it
> >> tries to run; Im looking at that now:
> >> 1283218480.397 DEBUG 000000 CWD: /
> >> 1283218480.397 DEBUG 000000 Running /bin/bash
> >> 1283218480.397 DEBUG 000000 Directory:
> >> /home/wilde/swiftwork/catsn-20100830-2034-hotqv61h-o-cat-oy\
> >> un22yj
> >> 1283218480.397 DEBUG 000000 Command: _swiftwrap.staging -e
> /bin/cat
> >> -out outdir/f.0001.out -err st\
> >> derr.txt -i -d |outdir -if data.txt -of outdir/f.0001.out -k
> -cdmfile
> >> -status provider -a data.tx\
> >> t
> >> 1283218480.397 DEBUG 000000 Command: /bin/bash _swiftwrap.staging
> -e
> >> /bin/cat -out outdir/f.0001.o\
> >> ut -err stderr.txt -i -d |outdir -if data.txt -of outdir/f.0001.out
> -k
> >> -cdmfile  -status provider \
> >> -a data.txt
> >> 1283218480.397 DEBUG 000000 1283218479990 Forked process 17949.
> >> Waiting for its completion
> >> 1283218480.408 DEBUG 000000 Checking jobs status (1 active)
> >> 1283218480.408 DEBUG 000000 1283218479990 Checking pid 17949
> >> 1283218480.408 DEBUG 000000 1283218479990 Job 17949 still running
> >> 1283218480.408 TRACE 000000  IN: len=2, actuallen=2, tag=4,
> flags=3,
> >> OK
> >> 1283218480.408 DEBUG 000000 Fin flag set
> >> 1283218480.508 DEBUG 000000 Checking jobs status (1 active)
> >> 1283218480.508 DEBUG 000000 1283218479990 Checking pid 17949
> >> 1283218480.508 DEBUG 000000 1283218479990 Child process 17949
> >> terminated. Status is 254.
> >> - Mike
> >> ----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> >>> On Mon, 2010-08-30 at 19:26 -0600, wilde at mcs.anl.gov wrote:
> >>>> I turned on the TRACE output level in worker.pl. I need to dig
> >>> deeper but it looks to me that the pathnames its trying to fetch
> >> are
> >>> getting mangled/confused with the file:// portion of the URI:
> >>>> org.globus.cog.karajan.workflow.service.ProtocolException:
> >>> java.io.FileNotFoundException:
> /autonfs/home/wilde/./file:/localhost/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging
> >>> (No such file or directory)
> >>>> The file
> >>> "/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging"
> >> does
> >>> exist on the client side.
> >>> Seems to. I gather "file" is broken.
> >>> Can you try "proxy", and see if it fails? If not, I'll know a bit
> >>> better
> >>> where to look.
> >>> Mihael
> >> Michael Wilde
> >> Computation Institute, University of Chicago
> >> Mathematics and Computer Science Division
> >> Argonne National Laboratory
> Justin M Wozniak
Michael Wilde
