[Swift-devel] Provider staging is failing
Justin M Wozniak
wozniak at mcs.anl.gov
Mon Aug 30 21:49:47 CDT 2010
I think that's ok. Do you have the wrapper.log/info files?
On Mon, 30 Aug 2010, Michael Wilde wrote:
> _swiftwrap.staging didnt sem to get marked executable:
> ----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
>> WIth proxy the stageins seem to complete. Then a get a 254 when it
>> tries to run; Im looking at that now:
>> 1283218480.397 DEBUG 000000 CWD: /
>> 1283218480.397 DEBUG 000000 Running /bin/bash
>> 1283218480.397 DEBUG 000000 Directory:
>> /home/wilde/swiftwork/catsn-20100830-2034-hotqv61h-o-cat-oy\
>> un22yj
>> 1283218480.397 DEBUG 000000 Command: _swiftwrap.staging -e /bin/cat
>> -out outdir/f.0001.out -err st\
>> derr.txt -i -d |outdir -if data.txt -of outdir/f.0001.out -k -cdmfile
>> -status provider -a data.tx\
>> t
>> 1283218480.397 DEBUG 000000 Command: /bin/bash _swiftwrap.staging -e
>> /bin/cat -out outdir/f.0001.o\
>> ut -err stderr.txt -i -d |outdir -if data.txt -of outdir/f.0001.out -k
>> -cdmfile -status provider \
>> -a data.txt
>> 1283218480.397 DEBUG 000000 1283218479990 Forked process 17949.
>> Waiting for its completion
>> 1283218480.408 DEBUG 000000 Checking jobs status (1 active)
>> 1283218480.408 DEBUG 000000 1283218479990 Checking pid 17949
>> 1283218480.408 DEBUG 000000 1283218479990 Job 17949 still running
>> 1283218480.408 TRACE 000000 IN: len=2, actuallen=2, tag=4, flags=3,
>> OK
>> 1283218480.408 DEBUG 000000 Fin flag set
>> 1283218480.508 DEBUG 000000 Checking jobs status (1 active)
>> 1283218480.508 DEBUG 000000 1283218479990 Checking pid 17949
>> 1283218480.508 DEBUG 000000 1283218479990 Child process 17949
>> terminated. Status is 254.
>> - Mike
>> ----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
>>> On Mon, 2010-08-30 at 19:26 -0600, wilde at mcs.anl.gov wrote:
>>>> I turned on the TRACE output level in worker.pl. I need to dig
>>> deeper but it looks to me that the pathnames its trying to fetch
>> are
>>> getting mangled/confused with the file:// portion of the URI:
>>>> org.globus.cog.karajan.workflow.service.ProtocolException:
>>> java.io.FileNotFoundException:
>> /autonfs/home/wilde/./file:/localhost/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging
>>> (No such file or directory)
>>>> The file
>>> "/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging"
>> does
>>> exist on the client side.
>>> Seems to. I gather "file" is broken.
>>> Can you try "proxy", and see if it fails? If not, I'll know a bit
>>> better
>>> where to look.
>>> Mihael
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
Justin M Wozniak
