[Swift-devel] Provider staging is failing
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Aug 30 20:39:26 CDT 2010
WIth proxy the stageins seem to complete. Then a get a 254 when it tries to run; Im looking at that now:
1283218480.397 DEBUG 000000 CWD: /
1283218480.397 DEBUG 000000 Running /bin/bash
1283218480.397 DEBUG 000000 Directory: /home/wilde/swiftwork/catsn-20100830-2034-hotqv61h-o-cat-oy\
un22yj
1283218480.397 DEBUG 000000 Command: _swiftwrap.staging -e /bin/cat -out outdir/f.0001.out -err st\
derr.txt -i -d |outdir -if data.txt -of outdir/f.0001.out -k -cdmfile  -status provider -a data.tx\
t
1283218480.397 DEBUG 000000 Command: /bin/bash _swiftwrap.staging -e /bin/cat -out outdir/f.0001.o\
ut -err stderr.txt -i -d |outdir -if data.txt -of outdir/f.0001.out -k -cdmfile  -status provider \
-a data.txt
1283218480.397 DEBUG 000000 1283218479990 Forked process 17949. Waiting for its completion
1283218480.408 DEBUG 000000 Checking jobs status (1 active)
1283218480.408 DEBUG 000000 1283218479990 Checking pid 17949
1283218480.408 DEBUG 000000 1283218479990 Job 17949 still running
1283218480.408 TRACE 000000  IN: len=2, actuallen=2, tag=4, flags=3, OK
1283218480.408 DEBUG 000000 Fin flag set
1283218480.508 DEBUG 000000 Checking jobs status (1 active)
1283218480.508 DEBUG 000000 1283218479990 Checking pid 17949
1283218480.508 DEBUG 000000 1283218479990 Child process 17949 terminated. Status is 254.
- Mike
----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> On Mon, 2010-08-30 at 19:26 -0600, wilde at mcs.anl.gov wrote:
> > I turned on the TRACE output level in worker.pl. I need to dig
> deeper but it looks to me that the pathnames its trying to fetch are
> getting mangled/confused with the file:// portion of the URI:
> > org.globus.cog.karajan.workflow.service.ProtocolException:
> java.io.FileNotFoundException:
> /autonfs/home/wilde/./file:/localhost/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging
> (No such file or directory)
> > The file
> "/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging" does
> exist on the client side.
> Seems to. I gather "file" is broken.
> Can you try "proxy", and see if it fails? If not, I'll know a bit
> better
> where to look.
> Mihael
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
