[Swift-devel] Provider staging is failing
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Aug 30 20:31:41 CDT 2010
On Mon, 2010-08-30 at 19:26 -0600, wilde at mcs.anl.gov wrote:
> I turned on the TRACE output level in worker.pl. I need to dig deeper but it looks to me that the pathnames its trying to fetch are getting mangled/confused with the file:// portion of the URI:
> org.globus.cog.karajan.workflow.service.ProtocolException: java.io.FileNotFoundException: /autonfs/home/wilde/./file:/localhost/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging (No such file or directory)
> The file "/home/wilde/swift/rev/trunk/bin/../libexec/_swiftwrap.staging" does exist on the client side.
Seems to. I gather "file" is broken.
Can you try "proxy", and see if it fails? If not, I'll know a bit better
where to look.
Mihael
