[Swift-devel] struct mapping code that formerly worked now fails
Mihael Hategan hategan at mcs.anl.gov
Mon Aug 23 00:28:28 CDT 2010
Yep.
Should be fixed in swift r3561.
I moved some of the functions in vdl-int.k and vdl.k from karajan to
Java for performance purposes. Some things got broken in the process.
Let me know if you find more things like this.
Mihael
On Sun, 2010-08-22 at 22:48 -0600, wilde at mcs.anl.gov wrote:
> Glen Hocky has a script that used to work but now fails under recent trunk revisions.
> Ive reproduced the failure in a simplified script:
> maptest2.swift is:
> type file;
> type mystruct {
>     file logfile;
> app (mystruct o) cat2log (file i)
>   cat @i stdout=@filename(o.logfile);
> int nmodels=1;
> mystruct modelOut[] <ext;exec="mystruct.map",n=nmodels>;
> file data<"data.txt">;
> foreach j in [0:nmodels-1] {
>   modelOut[j] = cat2log(data);
> mystruct.map is:
> #!/bin/bash
> nummodels=$2
> outdir=outdir
> for i in `seq 0 $(($nummodels-1))`;do
>     echo [$i].logfile $outdir/$i.log
> done
> Under a recent trunk this fails with:
> e$ swift maptest2.swift
> swift-r3490 (swift modified locally) cog-r2829 (cog modified locally)
> RunID: 20100823-0045-bmpsl452
> Progress:
> Execution failed:
>         org.griphyn.vdl.mapping.InvalidPathException: Invalid path (..logfile) for org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu,2008:swift:dataset:20100823-0045-r1xhema5:720000000009 type mystruct with no value at dataset=modelOut path=[0] (not closed)
> e$
> Under an older Swift it works:
> swift-r2974 cog-r2407
> RunID: 20100823-0047-j504gggc
> Progress:
> Final status:  Finished successfully:1
> e$
> Mihael, do you know what is causing this?  Can you reproduce the error using the script and mapper above?
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
