[Swift-devel] struct mapping code that formerly worked now fails
wilde at mcs.anl.gov wilde at mcs.anl.gov
Sun Aug 22 23:48:49 CDT 2010
Glen Hocky has a script that used to work but now fails under recent trunk revisions.
Ive reproduced the failure in a simplified script:
maptest2.swift is:
type file;
type mystruct {
    file logfile;
app (mystruct o) cat2log (file i)
  cat @i stdout=@filename(o.logfile);
int nmodels=1;
mystruct modelOut[] <ext;exec="mystruct.map",n=nmodels>;
file data<"data.txt">;
foreach j in [0:nmodels-1] {
  modelOut[j] = cat2log(data);
mystruct.map is:
#!/bin/bash
nummodels=$2
outdir=outdir
for i in `seq 0 $(($nummodels-1))`;do
    echo [$i].logfile $outdir/$i.log
done
Under a recent trunk this fails with:
e$ swift maptest2.swift
swift-r3490 (swift modified locally) cog-r2829 (cog modified locally)
RunID: 20100823-0045-bmpsl452
Progress:
Execution failed:
        org.griphyn.vdl.mapping.InvalidPathException: Invalid path (..logfile) for org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu,2008:swift:dataset:20100823-0045-r1xhema5:720000000009 type mystruct with no value at dataset=modelOut path=[0] (not closed)
e$
Under an older Swift it works:
swift-r2974 cog-r2407
RunID: 20100823-0047-j504gggc
Progress:
Final status:  Finished successfully:1
e$
Mihael, do you know what is causing this?  Can you reproduce the error using the script and mapper above?
- Mike
