[Swift-devel] Coaster error
Jonathan Monette jon.monette at gmail.com
Mon Aug 16 13:38:39 CDT 2010
Hello,
     I am getting this error when running coasters on PADS.
Canceling job 449188.svc.pads.ci.uchicago.edu
Canceling job 449189.svc.pads.ci.uchicago.edu
Failed to shut down block
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Failed to cancel task. qdel returned with an exit code of 153
     at
org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.cancel(AbstractExecutor.java:159)
     at
org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.cancel(AbstractJobSubmissionTaskHandler.java:85)
     at
org.globus.cog.abstraction.impl.common.AbstractTaskHandler.cancel(AbstractTaskHandler.java:70)
     at
org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:101)
     at
org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:90)
     at
org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.cancel(BlockTaskSubmitter.java:44)
     at
org.globus.cog.abstraction.coaster.service.job.manager.Block.forceShutdown(Block.java:293)
     at
org.globus.cog.abstraction.coaster.service.job.manager.Block$1.run(Block.java:284)
     at java.util.TimerThread.mainLoop(Timer.java:512)
     at java.util.TimerThread.run(Timer.java:462)
I am assuming is that coasters could not qdel a job.  As soon as this
error appeared all my jobs in the queue disappeared and no more jobs are
submitted.  My script hangs because it is waiting for some apps to run
but the jobs are never submitted to the PADS scheduler.  My run and all
the log files are located at
/home/jonmon/Workspace/Montage/m101_j_6x6/runs/m101_montage_Aug-16-2010_13-24-43
on the CI machines.
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
