[Swift-devel] cleanup fails on abe
Michael Wilde
wilde at mcs.anl.gov
Fri Aug 13 13:16:31 CDT 2010
Sarah, what does "shut off cleanup" mean?
Jon, is there any similarity between what Sarah is encountering and what you observed on TeraPort (presumably using provider=coaster jobmanager=local:pbs)?
- Mike
----- "Sarah Kenny" <skenny at uchicago.edu> wrote:
> hi all, not sure if anyone else is running on abe, but for some
> reason
> cleanup seems to fail on there very consistently. swift throws a
> warning:
> The following warnings have occurred:
> 1. Cleanup on ABE failed
> Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job
> at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:146)
> at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:100)
> at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
> at
> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:50)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
> Caused by: org.globus.gram.GramException: Parameter not supported
> at org.globus.gram.Gram.request(Gram.java:358)
> at org.globus.gram.GramJob.request(GramJob.java:262)
> at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:134)
> ... 4 more
> if i shut off cleanup, i don't get the warning and the workflow
> 'apprears' to have completed successfully, however even with cleanup
> shut off pbs still generates the email below giving the error:
> i'm still poking around to see if i can figure out what's up, but
> thought i would throw this out there in case someone else has come
> across it.
> swift, coaster and gram logs attached.
> ~sk
> ---------- Forwarded message ----------
> From: adm <adm at ncsa.uiuc.edu>
> Date: Fri, Aug 13, 2010 at 12:53 PM
> Subject: PBS JOB 3000582.abem5.ncsa.uiuc.edu
> To: skenny at abe1196.ncsa.uiuc.edu
> PBS Job Id: 3000582.abem5.ncsa.uiuc.edu
> Job Name: configtester
> Exec host:
> abe0553/0+abe0314/0+abe0313/0+abe0311/0+abe0310/0+abe0307/0+abe0294/0+abe0290/0+abe0287/0+abe0286/0+abe0285/0+abe0284/0+abe0283/0+abe0279/0+abe0278/0+abe0277/0+abe0275/0+abe0273/0+abe0272/0+abe0271/0+abe0256/0+abe0254/0+abe0174/0+abe0173/0+abe0166/0+abe0165/0+abe0163/0+abe0087/0+abe0085/0+abe0084/0+abe0010/0+abe0387/0
> An error has occurred processing your job, see below.
> Post job file processing error; job 3000582.abem5.ncsa.uiuc.edu on
> host
> Unable to copy file
> /u/ac/skenny/.pbs_spool//3000582.abem5.ncsa.uiuc.edu.OU to
> /u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stdout
> *** error from copy
> /bin/cp: cannot create regular file
> `/u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stdout':
> No such file or directory
> *** end error output
> Unable to copy file
> /u/ac/skenny/.pbs_spool//3000582.abem5.ncsa.uiuc.edu.ER to
> /u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stderr
> *** error from copy
> `/u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stderr':
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
