[Swift-devel] cleanup fails on abe
    Sarah Kenny
    skenny at uchicago.edu
    Fri Aug 13 13:11:08 CDT 2010
hi all, not sure if anyone else is running on abe, but for some reason
cleanup seems to fail on there very consistently. swift throws a
warning:
The following warnings have occurred:
1. Cleanup on ABE failed
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Cannot submit job
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:146)
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:100)
        at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
        at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:50)
        at org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
Caused by: org.globus.gram.GramException: Parameter not supported
        at org.globus.gram.Gram.request(Gram.java:358)
        at org.globus.gram.GramJob.request(GramJob.java:262)
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:134)
        ... 4 more
if i shut off cleanup, i don't get the warning and the workflow
'apprears' to have completed successfully, however even with cleanup
shut off pbs still generates the email below giving the error:
i'm still poking around to see if i can figure out what's up, but
thought i would throw this out there in case someone else has come
across it.
swift, coaster and gram logs attached.
~sk
---------- Forwarded message ----------
Date: Fri, Aug 13, 2010 at 12:53 PM
Subject: PBS JOB 3000582.abem5.ncsa.uiuc.edu
To: skenny at abe1196.ncsa.uiuc.edu
PBS Job Id: 3000582.abem5.ncsa.uiuc.edu
Job Name:   configtester
Exec host:  abe0553/0+abe0314/0+abe0313/0+abe0311/0+abe0310/0+abe0307/0+abe0294/0+abe0290/0+abe0287/0+abe0286/0+abe0285/0+abe0284/0+abe0283/0+abe0279/0+abe0278/0+abe0277/0+abe0275/0+abe0273/0+abe0272/0+abe0271/0+abe0256/0+abe0254/0+abe0174/0+abe0173/0+abe0166/0+abe0165/0+abe0163/0+abe0087/0+abe0085/0+abe0084/0+abe0010/0+abe0387/0
An error has occurred processing your job, see below.
Post job file processing error; job 3000582.abem5.ncsa.uiuc.edu on
host abe0553/0+abe0314/0+abe0313/0+abe0311/0+abe0310/0+abe0307/0+abe0294/0+abe0290/0+abe0287/0+abe0286/0+abe0285/0+abe0284/0+abe0283/0+abe0279/0+abe0278/0+abe0277/0+abe0275/0+abe0273/0+abe0272/0+abe0271/0+abe0256/0+abe0254/0+abe0174/0+abe0173/0+abe0166/0+abe0165/0+abe0163/0+abe0087/0+abe0085/0+abe0084/0+abe0010/0+abe0387/0
Unable to copy file
/u/ac/skenny/.pbs_spool//3000582.abem5.ncsa.uiuc.edu.OU to
/u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stdout
*** error from copy
/bin/cp: cannot create regular file
`/u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stdout':
No such file or directory
*** end error output
Unable to copy file
/u/ac/skenny/.pbs_spool//3000582.abem5.ncsa.uiuc.edu.ER to
/u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stderr
*** error from copy
`/u/ac/skenny/.globus/job/abe1196.ncsa.uiuc.edu/15575.1281721892/stderr':
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100813/917cac3d/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100813/917cac3d/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100813/917cac3d/attachment-0002.obj>
