[Swift-devel] Re: Worker connection
Allan Espinosa aespinosa at cs.uchicago.edu
Fri Aug 13 12:13:48 CDT 2010
So this is simply passed to the worker?  The "url" parameter is still the one
used to spawn the service right?
-Allan
On Fri, Aug 13, 2010 at 11:35:59AM -0500, Mihael Hategan wrote:
> On Fri, 2010-08-13 at 11:30 -0500, Jonathan Monette wrote:
> > Hello,
> >      How does the worker decide what connection to connect to?  Right
> > now what I think it does is it runs ifconfig and greps the inet address
> > and then test each of these connections.  Is this correct?  When I am
> > running on PADS it seems that the worker always chooses the wrong
> > connection to the service.  It seems to choose the UBS0 connection where
> > the correct connection is the ib0 connection.  Is there a way that maybe
> > the worker can be fixed to choose a better connection or the correct
> > connection?  This seems to be only happening on PADS.
> That was temporary. Initially it would use the same address as the url
> in sites.xml. Then I added the "try all interfaces" thing, but in some
> cases the connect on certain wrong addresses does not fail quickly
> enough and has to timeout instead, which usually takes a few minutes. So
> that got disabled and only the frist address is used now (unless
> overridden - see below).
> You can say <profile namespace="globus"
> key="internalHostname">x.y.z.w</profile> in sites.xml
