[Swift-devel] Re: Worker connection
Jonathan Monette
jon.monette at gmail.com
Fri Aug 13 11:43:36 CDT 2010
Right now I am using "internalHostname". I was just wondering if an
should this be changed since I am always changing this entry depending
if I am on login1 or login2?
On 8/13/10 11:35 AM, Mihael Hategan wrote:
> On Fri, 2010-08-13 at 11:30 -0500, Jonathan Monette wrote:
>> Hello,
>> How does the worker decide what connection to connect to? Right
>> now what I think it does is it runs ifconfig and greps the inet address
>> and then test each of these connections. Is this correct? When I am
>> running on PADS it seems that the worker always chooses the wrong
>> connection to the service. It seems to choose the UBS0 connection where
>> the correct connection is the ib0 connection. Is there a way that maybe
>> the worker can be fixed to choose a better connection or the correct
>> connection? This seems to be only happening on PADS.
> That was temporary. Initially it would use the same address as the url
> in sites.xml. Then I added the "try all interfaces" thing, but in some
> cases the connect on certain wrong addresses does not fail quickly
> enough and has to timeout instead, which usually takes a few minutes. So
> that got disabled and only the frist address is used now (unless
> overridden - see below).
> You can say<profile namespace="globus"
> key="internalHostname">x.y.z.w</profile> in sites.xml
> Mihael
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
