[Swift-devel] Fwd: Swift run failed in portal
Allan Espinosa aespinosa at cs.uchicago.edu
Thu Apr 29 16:52:17 CDT 2010
I got these errors from the stable branch as well.  I think I posted
this one in another thread.
-Allan
2010/4/29 Michael Wilde <wilde at mcs.anl.gov>:
> Mihael, just a note that Wenjun could use these patches committed.
> Note that I did *not* have time to try the language tests, which ideally should be done before committing.
> - Mike
> ----- Forwarded Message -----
> From: "wenjun wu" <wwjag at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Sent: Thursday, April 29, 2010 4:26:53 PM GMT -06:00 US/Canada Central
> Subject: Re: Swift run failed in portal
> Hi Mike,
>   You version of swift works fine with RaptorLoops. But I got some
> compilation issue after doing the two patches.
> Wenjun
>  [javac] Compiling 345 source files to
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/build
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/Catalog.java:24:
> warning: unmappable character for encoding UTF8
>     [javac]  * @author Jens-S. V�ckler
>     [javac]                     ^
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/CatalogEntry.java:21:
>     [javac]                     ^
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/util/Escape.java:36:
>     [javac]                     ^
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/util/ProfileParserException.java:23:
>     [javac]                     ^
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/util/Separator.java:25:
>     [javac]                     ^
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/griphyn/vdl/mapping/AbstractDataNode.java:543:
> closeDeepStructure() is already defined in
> org.griphyn.vdl.mapping.AbstractDataNode
>     [javac]     public void closeDeepStructure() {
>     [javac]                     ^
>     [javac]
> /autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java:51:
> cannot find symbol
>     [javac] symbol  : method getLast()
>     [javac] location: class org.griphyn.vdl.mapping.Path
>     [javac]                     markAsAvailable(stack,
> leaf.getParent(), leaf.getPathFromRoot().getLast());
> [javac]
>     [javac] Note: Some input files use or override a deprecated API.
>     [javac] Note: Recompile with -Xlint:deprecation for details.
>     [javac] 2 errors
>     [javac] 5 warnings
>> Wenjun, did the patched Swift release solve this problem?
>> Thanks,
>> Mike
>> ----- "wenjun wu"<wwjag at mcs.anl.gov>  wrote:
>>> It is located at
>>> /gpfs/pads/oops/scienceportal/apache-tomcat/webapps/SIDGridPortal/workflow/20100421/oops-20100421-1638-5up59v27
>>> Wenjun
>>>> Wenjun, Tom,
>>>> The run I started during our meeting failed:
>>>> Apr 21 16:38 - 5up59v27  Failed
>>>> How do I tell why?
>>>> Is there at least a server-side run directory that the user could
>>> navigate to within the CI filespace?
>>>> Thanks,
>>>> Mike
