[Swift-devel] Fwd: Swift run failed in portal
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 29 16:36:08 CDT 2010
Mihael, just a note that Wenjun could use these patches committed.
Note that I did *not* have time to try the language tests, which ideally should be done before committing.
- Mike
----- Forwarded Message -----
To: "Michael Wilde" <wilde at mcs.anl.gov>
Sent: Thursday, April 29, 2010 4:26:53 PM GMT -06:00 US/Canada Central
Subject: Re: Swift run failed in portal
Hi Mike,
   You version of swift works fine with RaptorLoops. But I got some
compilation issue after doing the two patches.
Wenjun
  [javac] Compiling 345 source files to
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/build
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/Catalog.java:24:
warning: unmappable character for encoding UTF8
     [javac]  * @author Jens-S. V�ckler
     [javac]                     ^
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/CatalogEntry.java:21:
     [javac]                     ^
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/util/Escape.java:36:
     [javac]                     ^
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/util/ProfileParserException.java:23:
     [javac]                     ^
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/globus/swift/catalog/util/Separator.java:25:
     [javac]                     ^
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/griphyn/vdl/mapping/AbstractDataNode.java:543:
closeDeepStructure() is already defined in
org.griphyn.vdl.mapping.AbstractDataNode
     [javac]     public void closeDeepStructure() {
     [javac]                     ^
     [javac]
/autonfs/gpfs-pads/projects/CI-MCB000009/scienceportal/swift-branch/cog/modules/swift/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java:51:
cannot find symbol
     [javac] symbol  : method getLast()
     [javac] location: class org.griphyn.vdl.mapping.Path
     [javac]                     markAsAvailable(stack,
leaf.getParent(), leaf.getPathFromRoot().getLast());
[javac]
     [javac] Note: Some input files use or override a deprecated API.
     [javac] Note: Recompile with -Xlint:deprecation for details.
     [javac] 2 errors
     [javac] 5 warnings
> Wenjun, did the patched Swift release solve this problem?
> Thanks,
> Mike
> ----- "wenjun wu"<wwjag at mcs.anl.gov>  wrote:
>> It is located at
>> /gpfs/pads/oops/scienceportal/apache-tomcat/webapps/SIDGridPortal/workflow/20100421/oops-20100421-1638-5up59v27
>> Wenjun
>>> Wenjun, Tom,
>>> The run I started during our meeting failed:
>>> Apr 21 16:38 - 5up59v27  Failed
>>> How do I tell why?
>>> Is there at least a server-side run directory that the user could
>> navigate to within the CI filespace?
>>> Thanks,
>>> Mike
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
