[Swift-devel] process hogging memory on ranger login
Mihael Hategan
hategan at mcs.anl.gov
Mon Nov 23 19:25:55 CST 2009
On Mon, 2009-11-23 at 19:01 -0600, skenny at uchicago.edu wrote:
> >On Fri, 2009-11-20 at 13:01 -0600, skenny at uchicago.edu wrote:
> >> so, using the latest swift (swift-r3116 cog-r2482) i submitted
> >> a 1,179,647-job workflow to ranger...got this far:
> >> Progress: Submitted:16378 Active:1 Finished
> successfully:412482
> >> was in that state for a while (~24hrs) showing this in the
> queue:
> >> 1143906 data tg457040 Waiting 2944 01:10:00
> >> Thu Nov 19 07:22:48
> >Logs would help.
> so, i was trying to re-run this workflow with the latest swift
> (swift-r3191 cog-r2620) to try and replicate the error.
> however, a new error has surfaced...the environment, as
> specified in my tc.data file, is no-longer being set by swift
> on the remote end. is it possible this is due to recent
> changes in swift? i am running the same workflow, same tc &
> sites files with the newer swift and am getting errors (from
> the app) due to my LD_LIBRARY_PATH not being set. if i switch
> back to swift-r3116 cog-r2482, the error goes away.
Yes. That is possible.
I will check.
Can you post your sites file?
