[Swift-devel] Swift and BGP
Mihael Hategan hategan at mcs.anl.gov
Wed Nov 18 19:52:59 CST 2009
On Wed, 2009-11-18 at 18:00 -0600, skenny at uchicago.edu wrote:
> >> >> (though that depends on the structure of the program).
> >> >> - run on login6. There is no point in using the normal
> >> login machines
> >> >> since they have a limit of 1024 file descriptors per
> process.
> >> so, am i correct in understanding that currently swift can
> >> only run on login6 when running on intrepid? i ask because i'm
> >> currently not able to get on login6, but decided to try a
> >> 512-job workflow on login3 and got this:
> >Right. The error below is precisely the reason why login6 is
> needed.
> do you think it's worth writing to support to see if they'd be
> willing to up the limit on the other login nodes since login6
> is down?
Might be. But I think it's also worth mentioning that login6 is down.
