[Swift-devel] Swift and BGP
skenny at uchicago.edu
Wed Nov 18 18:00:59 CST 2009
>> >> (though that depends on the structure of the program).
>> >> - run on login6. There is no point in using the normal
>> login machines
>> >> since they have a limit of 1024 file descriptors per
process.
>> so, am i correct in understanding that currently swift can
>> only run on login6 when running on intrepid? i ask because i'm
>> currently not able to get on login6, but decided to try a
>> 512-job workflow on login3 and got this:
>Right. The error below is precisely the reason why login6 is
needed.
do you think it's worth writing to support to see if they'd be
willing to up the limit on the other login nodes since login6
is down?
