[Fwd: Re: [Swift-devel] Problems with Swift trunk on abe]
Michael Wilde wilde at mcs.anl.gov
Tue Nov 3 11:23:54 CST 2009
Indeed, taking 0024-compound, and just copying it to a local test
directory, gives very similar *and random, various* errors.
See below (abe: ~wilde/swiftbug for logs)
Still digging.
- Mike
honest4$ which swift
~/swift/src/cog/modules/swift/dist/swift-svn/bin/swift
honest4$ cat >t.swift
type messagefile {}
(messagefile t) greeting(string m) {
     app {
         echo m stdout=@filename(t);
(messagefile first, messagefile second) compound() {
   first = greeting("f");
   second = greeting("s");
messagefile a <"0024-compound.Q.out">;
messagefile b <"0024-compound.R.out">;
(a,b) = compound();
honest4$
honest4$ pwd
/u/ac/wilde/swiftbug
honest4$
honest4$ swift t.swift
Swift svn swift-r3186 cog-r2572
RunID: 20091103-1120-xnfyl1i5
Progress:
Failed to transfer wrapper log from t-20091103-1120-xnfyl1i5/info/k on
localhost
Progress:  Stage in:1  Finished successfully:1
Final status:  Finished successfully:2
RunID: 20091103-1121-2pgjnht8
Progress:
Execution failed:
	First argument must be an identifier or a list of identifiers
RunID: 20091103-1121-m64zk3p8
Progress:
Execution failed:
	Variable not found: r
Failed to transfer wrapper log from t-20091103-1121-m64zk3p8/info/p on
localhost
RunID: 20091103-1121-effamg5e
Progress:
Ex098
org.globus.cog.karajan.workflow.KarajanRuntimeException: Invalid
identifier: [$, org.griphyn.vdl.mapping.RootDataNode identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20091103-1121-5rjnv1z5:720000000004
type messagefile with no value at dataset=b (not closed)]
	at org.globus.cog.karajan.util.TypeUtil.toIdentifier(TypeUtil.java:286)
	at
org.globus.cog.karajan.workflow.nodes.ChannelTo.partialArgumentsEvaluated(ChannelTo.java:32)
	at
org.globus.cog.karajan.workflow.nodes.PartialArgumentsContainer.childCompleted(PartialArgumentsContainer.java:81)
	at
org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
	at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:134)
	at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:108)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:296)
	at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialIterator.iterationCompleted(AbstractSequentialIterator.java:90)
	at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialIterator.nonArgChildCompleted(AbstractSequentialIterator.java:75)
	at
org.globus.cog.karajan.workflow.nodes.PartialArgumentsContainer.childCompleted(PartialArgumentsContainer.java:85)
	at
	at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialIterator.notificationEvent(AbstractSequentialIterator.java:132)
	at
	at
	at
	at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
	at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
	at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
	at
	at
	at
	at
	at
	at
	at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
	at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
	at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
	at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
	at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:229)
	at
	at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:43)
	at
edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
	at
edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
	at
edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
	at
edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
	at java.lang.Thread.run(Thread.java:595)
Execution failed:
	Invalid identifier: [$, org.griphyn.vdl.mapping.RootDataNode identifier
honest4$
On 11/3/09 11:15 AM, Michael Wilde wrote:
> Im running the Swift test battery on Ranger and Abe.
> Tests on Abe just got this, which is similar to what I was seeing:
> Running test 0024-compound at Tue Nov 3 11:11:33 CST 2009
> RunID: 20091103-1111-as1yb7s3
> Progress:
> Execution failed:
> SWIFT RETURN CODE NON-ZERO - test 0024-compound.swift
> Ranger passed all syntax tests but is hanging on 001-echo. Not sure why yet.
> I'll keep trying to zero in on something small thats reproducble.
> 0024-compound might be a good starting point.
> Let me know if you need something specific from me, or have suggestions
> on what to try, where.
> Thanks,
> Mike
> On 11/3/09 11:05 AM, Mihael Hategan wrote:
>> Thanks. I'm looking into it.
>> On Tue, 2009-11-03 at 10:19 -0600, Michael Wilde wrote:
>>> Similar problems happen on Ranger.  I used an older Swift build
>>> initially, and it ran.
>>> Then I updated to the latest, and I get the following similar failure:
>>> RunID: 20091103-1016-khfn59yf
>>> Progress:
>>> Ex098
>>> java.lang.NullPointerException
>>>          at
>>> org.globus.cog.karajan.workflow.nodes.functions.Variable.function(Variable.java:38)
>>>          at
>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
>>>          at
>>>          at
>>>          at java.lang.Thread.run(Thread.java:619)
>>> Execution failed:
>>>          Argument size mismatch. Got 1 names and 2 values
>>> login3$
>>> Im going try the bgp next. If it works there, we can leave this issue
>>> for after SC. Else, I'll need to resolve it.
>>> - Mike
>>> -------- Original Message --------
>>> Subject: Re: [Swift-devel] Problems with Swift trunk on abe
>>> Date: Tue, 03 Nov 2009 08:18:55 -0600
>>> From: Michael Wilde <wilde at mcs.anl.gov>
>>> To: swift-devel <swift-devel at ci.uchicago.edu>
>>> References: <4AF03842.70300 at mcs.anl.gov>
>>> Using the Swift build (and swift.properties) that works on communicado,
>>> I still get the same failures on Abe.
>>> I'm going to try a few other systems to see if the problem is widespread
>>> or local to Abe.
>>> - Mike
>>> On 11/3/09 8:03 AM, Michael Wilde wrote:
>>>> What seems like the a build of the same Swift & CoG svn revision is
>>>> working on communicado but giving strange and transient results on Abe.
>>>> A series of 5 runs of the same code (with .xml and .kml files left in
>>>> place) give the set of errors below.
>>>> I will try to use the release build on communicado, to see if this is
>>>> being caused by some Java compiler difference on Abe.
>>>> Suggestions welcome. Mihael, I can get you the logs - they are on abe in
>>>> ~wilde/run.58, along with the source: psim.basicex1.swift
>>>> - Mike
>>>> Output with a few progress and blank lines removed:
>>>> (full output is in: http://www.ci.uchicago.edu/~wilde/abe.swiftproblem.txt )
>>>> honest4$ ls
>>>> Protein.map*  Protein.map~*  etc  input@  logs/  psim.basicex1.swift*
>>>> sites.xml  t.swift*  t.swift~*  tc  tc~
>>>> honest4$ swift -tc.file tc -sites.file sites.xml psim.basicex1.swift
>>>> RunID: 20091103-0750-p7z85z61
>>>> Execution failed:
>>>>          Argument size mismatch. Got 5 names and 0 values
>>>> RunID: 20091103-0751-sfxthnne
>>>> Execution failed:
>>>> RunID: 20091103-0751-oxnhztrc
>>>> Progress:
>>>> Execution failed:
>>>> RunID: 20091103-0751-amtfuvq9
>>>> Execution failed:
>>>>          Variable not found: path
>>>> RunID: 20091103-0751-b4sr44x2
>>>> Execution failed:
>>>>          Ex098
>>>> identifier: [$, org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uch\
>>>> icago.edu,2008:swift:dataset:20091103-0751-b65c863d:720000000020 type
>>>> ProtGeo with no value at dataset=structure path=[1] (not closed)]
>>>>          at
>>>> honest4$
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
