[Swift-devel] block allocation
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May 25 10:55:31 CDT 2009
Great. Thanks.
On Mon, 2009-05-25 at 10:51 -0500, Ioan Raicu wrote:
> At least on the BG/P using Cobalt, the reservations are based on user
> IDs and queues. Once a reservation is in place, and it has certain
> users associated with that reservation, those users can simply submit
> jobs to the specific queue (unique to that reservation, and is usually
> named by the sys admin that sets up the reservation, e.g.
> R.Falkon-8K), and the jobs will run under that reservation. Other
> systems such as PBS/SGE/Condor could be different, I don't know.
> Ioan
> Mihael Hategan wrote:
> > On Mon, 2009-05-25 at 07:16 +0000, Ben Clifford wrote:
> > > On Sun, 24 May 2009, Mihael Hategan wrote:
> > > > PS: On the topic of static allocations, in people's experience, how does
> > > > one specify reservations on various resources?
> > > I've only done that by sending email to help at teragrid.org, which is a
> > > relatively high latency and expensive operation.
> > Right. But once you have the reservation, I assume you have a mechanism
> > of specifying which of your jobs should make use of it and which
> > shouldn't. Like a reservation id. That mechanism is what I'm interested
> > in.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Ioan Raicu, Ph.D.
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
> http://dev.globus.org/wiki/Incubator/Falkon
> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
