[Swift-devel] RE: [Swift-user] Execution error]]
    Michael Wilde
    wilde at mcs.anl.gov
    Thu May 21 13:14:34 CDT 2009
On 5/21/09 12:39 PM, Zhao Zhang wrote:
> Hi, Mike
> I did repeat this bug on ranger with 100 jobs. The log is at
> /home/zzhang/scip/scip_100_fail_log
> Then I set
> <profile namespace="globus" key="coasterMaxJobs">5</profile>
> The same work flow ran perfectly.
OK, thats good to hear.
I thought the limit on Ranger was 50, though.
Can you repeat the test at coasterMaxJobs 50 (or whatever the documented
limit is)?
> I ran scip workflow with 16, 64 128, 256, 512, 1024 jobs.
> One thing I concerned is that there might be noise in the tests, the
> end-to-end time could not be the real running time
> for the workflow.
I dont understand what you mean?  That the numbers below are too fast to
be believable?
- Mike
> Here is the summary for running time:
> 16  173 seconds
> 64  132 seconds
> 128  166 seconds
> 256  202 seconds
> 512  221 seconds
> 1024  400 seconds
> The logs are at
> /home/zzhang/scip/scip_16_log
> /home/zzhang/scip/scip_64_log
> /home/zzhang/scip/scip_128_log
> /home/zzhang/scip/scip_256_log
> /home/zzhang/scip/scip_512_log
> /home/zzhang/scip/scip_1024_log
> zhao
> Michael Wilde wrote:
>> Zhao, here is the latest Coaster bug fix I am aware of, to test.
>> This was a showstopper bug for Glen, as once he exceeded the job
>> limit, it *seemed* as I understand that Ranger killed all his jobs.
>> - Mike
>> -------- Original Message --------
>> Subject: [Fwd: Re: [Swift-devel] RE: [Swift-user] Execution error]
>> Date: Tue, 12 May 2009 15:38:52 -0500
>> From: Michael Wilde <wilde at mcs.anl.gov>
>> To: Glen Hocky <hockyg at uchicago.edu>,  Mihael Hategan
>> <hategan at mcs.anl.gov>
>> Glen, the bug you were asking about yesterday was fixed on May 1 -
>> here's the email from Mihael.
>> Did you try this fix, or were you unaware of this particular message in
>> the thread on that problem?
>> - Mike
>> Subject: Re: [Swift-devel] RE: [Swift-user] Execution error
>> Date: Fri, 01 May 2009 15:22:02 -0500
>> From: Mihael Hategan <hategan at mcs.anl.gov>
>> CC: swift-devel <swift-devel at ci.uchicago.edu>,    "Yue,  Chen - BMD"
>> <yuechen at bsd.uchicago.edu>
>> References:
>> <AD1FA15416EEBC49A0FE4F8B0C8AD7C5158CB1 at ADM-EXCHVS04.bsdad.uchicago.edu>
>> <49F9DE8F.1070404 at mcs.anl.gov>
>> <49F9E298.8030801 at mcs.anl.gov>    <49F9E8FB.9020500 at mcs.anl.gov>
>> <AD1FA15416EEBC49A0FE4F8B0C8AD7C5158CB4 at ADM-EXCHVS04.bsdad.uchicago.edu>
>> <49F9F680.6040503 at mcs.anl.gov>
>> <AD1FA15416EEBC49A0FE4F8B0C8AD7C5158CB5 at ADM-EXCHVS04.bsdad.uchicago.edu>
>> <49FA03EA.7080807 at mcs.anl.gov>
>> <AD1FA15416EEBC49A0FE4F8B0C8AD7C5158CB6 at ADM-EXCHVS04.bsdad.uchicago.edu>
>> <49FA147E.6070205 at uchicago.edu>
>>  <1241135666.3603.1.camel at localhost>
>> Fix in cog 2394.
>> Use globus:coasterMaxJobs profile.
>> On Thu, 2009-04-30 at 18:54 -0500, Mihael Hategan wrote:
>>> Mystery solved:
>>> Thu Apr 30 18:19:13 2009 JM_SCRIPT:   ERROR: job submission failed:
>>>       Welcome to TACC's Ranger System, an NSF TeraGrid Resource
>>>   --> Submitting 16 tasks...
>>>   --> Submitting 16 tasks/host...
>>>   --> Submitting exclusive job to 1 hosts...
>>>   --> Verifying HOME file-system availability...
>>>   --> Verifying WORK file-system availability...
>>>   --> Verifying SCRATCH file-system availability...
>>>   --> Ensuring absence of dubious h_vmem,h_data,s_vmem,s_data limits...
>>>   --> Requesting valid memory configuration (mt=31.3G)...
>>>   --> Checking ssh keys...
>>>   --> Checking file existence and permissions for passwordless ssh...
>>>   --> Verifying accounting...
>>>    ERROR: You have exceeded the max submitted job count.
>>>    Maximum allowed is 50 jobs.
>>>    Please contact TACC Consulting if you believe you have
>>>    received this message in error.
>>> Job aborted by esub.
>>> I'll add a limit for the number of jobs allowed to the current coaster
>>> code.
>>> On Thu, 2009-04-30 at 16:13 -0500, Glen Hocky wrote:
>>> > I have the identical response on ranger. It started yesterday
>>> evening. > Possibly a problem that the TACC folks need to fix?
>>> > > Glen
>>> > > Yue, Chen - BMD wrote:
>>> > > Hi Michael,
>>> > >  > > Thank you for the advices. I tested ranger with 1 job and
>>> new > > specifications of maxwalltime. It shows the following error
>>> message. I > > don't know if there is other problem with my setup.
>>> Thank you!
>>> > > [yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift
>>> -sites.file > > sites.xml -tc.file tc.data
>>> > > Swift 0.9rc2 swift-r2860 cog-r2388
>>> > > RunID: 20090430-1559-2vi6x811
>>> > > Progress:
>>> > > Progress:  Stage in:1
>>> > > Progress:  Submitting:1
>>> > > Progress:  Submitted:1
>>> > > Progress:  Active:1
>>> > > Failed to transfer wrapper log from > >
>>> PTMap2-unmod-20090430-1559-2vi6x811/info/i on ranger
>>> > > Progress:  Active:1
>>> PTMap2-unmod-20090430-1559-2vi6x811/info/k on ranger
>>> > > Progress:  Active:1
>>> PTMap2-unmod-20090430-1559-2vi6x811/info/m on ranger
>>> > > Progress:  Failed:1
>>> > > Execution failed:
>>> > >         Exception in PTMap2:
>>> > > Arguments: [e04.mzXML, ./seqs-ecolik12/fasta01, inputs-unmod.txt,
>>> > > parameters.txt]
>>> > > Host: ranger
>>> > > Directory:
>>> PTMap2-unmod-20090430-1559-2vi6x811/jobs/m/PTMap2-mbe6m5aj
>>> > > stderr.txt:
>>> > > stdout.txt:
>>> > > Caused by:
>>> > >         Failed to start worker:
>>> > > null
>>> > > null
>>> > > org.globus.gram.GramException: The job manager detected an
>>> invalid > > script response
>>> > >         at > >
>>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>>> > >         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>> > >         at > >
>>> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>> > >         at java.lang.Thread.run(Thread.java:619)
>>> > > Cleaning up...
>>> > > Shutting down service at https://129.114.50.163:45562 > >
>>> <https://129.114.50.163:45562>
>>> > > Got channel MetaChannel: 20903429 -> GSSSChannel-null(1)
>>> > > - Done
>>> > >  > > Chen, Yue
>>> > > *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
>>> > > *Sent:* Thu 4/30/2009 3:02 PM
>>> > > *To:* Yue, Chen - BMD; swift-devel
>>> > > *Subject:* Re: [Swift-user] Execution error
>>> > > Back on list here (I only went off-list to discuss accounts, etc)
>>> > > The problem in the run below is this:
>>> > > 2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2
>>> APPLICATION_EXCEPTION
>>> > > jobid=PTMap2-abeii5aj - Application exception: Job cannot be run
>>> with
>>> > > the given max walltime worker constraint (task: 3000, \
>>> > > maxwalltime: 2400s)
>>> > > You have this on the ptmap app in your tc.data:
>>> > > globus::maxwalltime=50
>>> > > But you only gave coasters 40 mins per coaster worker. So its
>>> > > complaining that it cant run a 50 minute job in a 40 minute (max)
>>> > > coaster worker. ;)
>>> > > I mentioned in a prior mail that you need to set the two time
>>> vals in
>>> > > your sites.xml entry; thats what you need to do next, now.
>>> > > change the coaster time in your sites.xml to:
>>> > >      key="coasterWorkerMaxwalltime">00:51:00</profile>
>>> > > If you have more info on the variability of your ptmap run times,
>>> send
>>> > > that to the list, and we can discuss how to handle.
>>> > > (NOTE: doing grp -i of the log for "except" or scanning for "except"
>>> > > with an editor will often locate the first "exception" that your job
>>> > > encountered. Thats how I found the error above).
>>> > > Also, Yue, for testing new sites, or for validating that old
>>> sites still
>>> > > work, you should create the smallest possible ptmap workflow - 1
>>> job if
>>> > > that is possible - and verify that this works.  Then say 10 jobs
>>> to make
>>> > > sure scheduling etc is sane.  Then, send in your huge jobs.
>>> > > With only 1 job, its easier to spot the errors in the log file.
>>> > > - Mike
>>> > > On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
>>> > > > Hi Michael,
>>> > > > > > > I run into the same messages again when I use Ranger:
>>> > > > > > > Progress:  Selecting site:146  Stage in:25
>>> Submitting:15  Submitted:821
>>> > > > Failed but can retry:16
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
>>> > > > Progress:  Selecting site:146  Stage in:3  Submitting:1
>>> Submitted:857
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
>>> > > > PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
>>> > > > The log for the search is at : > > >
>>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
>>> > > > > > > The sites.xml I have is:
>>> > > > > > >  <pool handle="ranger">
>>> > > >      <execution provider="coaster"
>>> > > >                 url="gatekeeper.ranger.tacc.teragrid.org"
>>> > > >                 jobManager="gt2:gt2:SGE"/>
>>> > > >      <gridftp
>>> url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
>>> > > >      <profile namespace="env"
>>> key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
>>> key="project">TG-CCR080022N</profile>
>>> key="coastersPerNode">16</profile>
>>> > > >      <profile namespace="globus" key="queue">development</profile>
>>> > > >               key="coasterWorkerMaxwalltime">00:40:00</profile>
>>> > > >      <profile namespace="globus" key="maxwalltime">31</profile>
>>> > > >      <profile namespace="karajan" key="initialScore">50</profile>
>>> > > >      <profile namespace="karajan" key="jobThrottle">10</profile>
>>> > > >      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
>>> > > >  </pool>
>>> > > > The tc.data I have is:
>>> > > > > > > ranger          PTMap2         > > >
>>> /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED      > > >
>>> INTEL32::LINUX  globus::maxwalltime=50
>>> > > > I'm using swift 0.9 rc2
>>> > > > Thank you very much for help!
>>> > > > Chen, Yue
>>> > > > *Sent:* Thu 4/30/2009 2:05 PM
>>> > > > On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
>>> > > >  > Hi Michael,
>>> > > >  > When I tried to activate my account, I encountered the
>>> following > > error:
>>> > > >  > "Sorry, this account is in an invalid state. You may not
>>> activate > > your
>>> > > >  > at this time."
>>> > > >  > I used the username and password from TG-CDA070002T. Should
>>> I use a
>>> > > >  > different password?
>>> > > > If you can already login to Ranger, then you are all set - you
>>> must have
>>> > > > done this previously.
>>> > > > I thought you had *not*, because when I looked up your login on
>>> ranger
>>> > > > ("finger yuechen") it said "never logged in". But seems like
>>> that info
>>> > > > is incorrect.
>>> > > > If you have ptmap compiled, seems like you are almost all set.
>>> > > > Let me know if it works.
>>> > > > - Mike
>>> > > >  > Thanks!
>>> > > >  > Chen, Yue
>>> > > >  > *Sent:* Thu 4/30/2009 1:07 PM
>>> > > >  > *Cc:* swift user
>>> > > >  > Yue, use this XML pool element to access ranger:
>>> > > >  >      <gridftp > >
>>> > > >  >      <profile namespace="globus" > >
>>> <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
>>> > > >  >    </pool>
>>> > > >  > You will need to also do these steps:
>>> > > >  > Go to this web page to enable your Ranger account:
>>> > > >  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
>>> > > >  > Then login to Ranger via the TeraGrid portal and put your
>>> ssh keys in
>>> > > >  > place (assuming you use ssh keys, which you should)
>>> > > >  > While on Ranger, do this:
>>> > > >  > echo $WORK
>>> > > >  > mkdir $work/swiftwork
>>> > > >  > and put the full path of your $WORK/swiftwork directory in the
>>> > > >  > <workdirectory> element above. (My login is tg455etc, yours
>>> is > > yuechen)
>>> > > >  > Then scp your code to Ranger and compile it.
>>> > > >  > Then create a tc.data entry for your ptmap app
>>> > > >  > Next, set your time values in the sites.xml entry above to
>>> suitable
>>> > > >  > values for Ranger. You'll need to measure times, but I think
>>> you will
>>> > > >  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
>>> > > >  > The values above were set for one app job per coaster. I
>>> think > > you can
>>> > > >  > probably do more.
>>> > > >  > If you estimate a run time of 5 minutes, use:
>>> > > >  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
>>> > > >  >      <profile namespace="globus" key="maxwalltime">5</profile>
>>> > > >  > Other people on the list - please sanity check what I
>>> suggest here.
>>> > > >  > - Mike
>>> > > >  > On 4/30/09 12:40 PM, Michael Wilde wrote:
>>> > > >  >  > I just checked - TG-CDA070002T has indeed expired.
>>> > > >  >  > The best for now is to move to use (only) Ranger, under
>>> this > > account:
>>> > > >  >  > TG-CCR080022N
>>> > > >  >  > I will locate and send you a sites.xml entry in a moment.
>>> > > >  >  > You need to go to a web page to activate your Ranger login.
>>> > > >  >  > Best to contact me in IM and we can work this out.
>>> > > >  >  > - Mike
>>> > > >  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
>>> > > >  >  >> Also, what account are you running under? We may need to
>>> change
>>> > > > you to
>>> > > >  >  >> a new account - as the OSG Training account expires today.
>>> > > >  >  >> If that happend at Noon, it *might* be the problem.
>>> > > >  >  >> - Mike
>>> > > >  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
>>> > > >  >  >>> Hi,
>>> > > >  >  >>> I came back to re-run my application on NCSA Mercury
>>> which was
>>> > > > tested
>>> > > >  >  >>> successfully last week after I just set up coasters
>>> with > > swift 0.9,
>>> > > >  >  >>> but I got many messages like the following:
>>> > > >  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
>>> > > >  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190
>>> Failed
>>> > > > but can
>>> > > >  >  >>> retry:1
>>> > > >  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556
>>> Failed > > but can
>>> > > >  >  >>> retry:4
>>> > > >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
>>> > > >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
>>> > > >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
>>> > > >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
>>> > > >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
>>> > > >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
>>> > > >  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed
>>> but can
>>> > > > retry:8
>>> > > >  >  >>> Progress:  Submitted:1011  Active:1 Failed but can
>>> retry:11
>>> > > >  >  >>> The log file for the successful run last week is ;
>>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
>>> > > >  >  >>> The log file for the failed run is :
>>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
>>> > > >  >  >>> I don't think I did anything different, so I don't know
>>> why this
>>> > > > time
>>> > > >  >  >>> they failed. The sites.xml for Mercury is:
>>> > > >  >  >>>  <pool handle="NCSA_MERCURY">
>>> > > >  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
>>> > > >  >  >>>     <execution provider="coaster" > >
>>> url="grid-hg.ncsa.teragrid.org"
>>> > > >  >  >>> jobManager="gt2:PBS"/>
>>> <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
>>> key="queue">debug</profile>
>>> > > >  >  >>>  </pool>
>>> > > >  >  >>> Thank you for help!
>>> > > >  >  >>> Chen, Yue
>>> > > >  >  >>> This email is intended only for the use of the
>>> individual or > > entity
>>> > > >  >  >>> to which it is addressed and may contain information
>>> that is
>>> > > >  >  >>> privileged and confidential. If the reader of this
>>> email > > message is
>>> > > >  >  >>> not the intended recipient, you are hereby notified
>>> that any
>>> > > >  >  >>> dissemination, distribution, or copying of this
>>> communication is
>>> > > >  >  >>> prohibited. If you have received this email in error,
>>> please > > notify
>>> > > >  >  >>> the sender and destroy/delete all copies of the
>>> transmittal.
>>> > > > Thank you.
>>> > > >  >  >>> _______________________________________________
>>> > > >  >  >>> Swift-user mailing list
>>> > > >  >  >>> Swift-user at ci.uchicago.edu
>>> > > >  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>>> > > >  > This email is intended only for the use of the individual or
>>> > > entity to
>>> > > >  > which it is addressed and may contain information that is >
>>> > privileged and
>>> > > >  > confidential. If the reader of this email message is not the
>>> intended
>>> > > >  > recipient, you are hereby notified that any dissemination, >
>>> > distribution,
>>> > > >  > or copying of this communication is prohibited. If you have
>>> received
>>> > > >  > this email in error, please notify the sender and
>>> destroy/delete all
>>> > > >  > copies of the transmittal. Thank you.
>>> entity to
>>> privileged and
>>> intended
>>> distribution,
>>> received
>>> destroy/delete all
>>> entity to > > which it is addressed and may contain information that
>>> is privileged > > and confidential. If the reader of this email
>>> message is not the > > intended recipient, you are hereby notified
>>> that any dissemination, > > distribution, or copying of this
>>> communication is prohibited. If you > > have received this email in
>>> error, please notify the sender and > > destroy/delete all copies of
>>> > > Swift-devel mailing list
>>> > > Swift-devel at ci.uchicago.edu
>>> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
