[Swift-devel] Re: coaster features
Mihael Hategan
hategan at mcs.anl.gov
Mon May 18 16:39:56 CDT 2009
Excellent! Please put this in bugzilla, and refer to the bug number
whenever necessary.
Mihael
On Mon, 2009-05-18 at 16:32 -0500, Zhao Zhang wrote:
> Thanks, Mihael. I am stating that bug again.
> I wrote a swift script to test the coaster-data-provider.
> [zzhang at communicado 1KB]$ cat data-test.swift
> type Mol {}
> type DOCKOut {}
> app (DOCKOut ofile) cat (Mol molfile)
> cat @filename(molfile) stdout=@filename(ofile);
> Mol texts[] <filesys_mapper;location="input/", suffix=".mol2">;
> doall(Mol texts[])
> foreach p in texts {
> DOCKOut r <regexp_mapper;
> source=@p,
> match="input/(.*)\\.mol2",
> transform=@strcat("result/", "\\1", ".out")
> (r) = cat(p);
> // Main
> doall(texts);
> It copies a file "D00001.mol2", then redirects the file to "D00001.out",
> "D00001.out" is taken as the output file.
> I have two test cases on CI netowrk,
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/swift_data_test/1KB
> and
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/swift_data_test/1MB
> If you want to repeat the test, you will also need
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/tc.data and
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/coaster_test/AGLT2.xml
> [zzhang at communicado 1MB]$ cat ../../coaster_test/AGLT2.xml
> <config>
> <!-- AGLT2 -->
> <pool handle="AGLT2" >
> <filesystem provider="coaster" url="gt2://gate01.aglt2.org" />
> <execution provider="coaster" url="gate01.aglt2.org"
> jobManager="gt2:gt2:condor"/>
> <workdirectory >/atlas/data08/OSG/DATA/osg/tmp/AGLT2</workdirectory>
> </pool>
> </config>
> So, I ran the test twice with those two cases.
> [zzhang at communicado 1KB]$ swift -sites.file ../../coaster_test/AGLT2.xml
> -tc.file ../../tc.data data-test.swift
> Swift svn swift-r2896 cog-r2392
> RunID: 20090518-1355-dksv64l5
> Progress:
> Progress: Stage in:1
> Progress: Submitting:1
> Progress: Submitted:1
> Progress: Active:1
> Final status: Finished successfully:1
> Cleaning up...
> Shutting down service at https://192.41.230.11:41507
> Got channel MetaChannel: 7132795 -> GSSSChannel-null(1)
> - Done
> [zzhang at communicado input]$ cksum D00001.mol2
> 2023409842 1054 D00001.mol2
> [zzhang at communicado input]$ cksum ../result/D00001.out
> 2023409842 1054 ../result/D00001.out
> The 1KB test case is fine. Then I tried 1MB test case
> [zzhang at communicado 1MB]$ swift -sites.file ../../coaster_test/AGLT2.xml
> RunID: 20090518-1357-ad024vu1
> Progress:
> Progress: Active:1
> Progress: Finished successfully:1
> Cleaning up...
> Shutting down service at https://192.41.230.11:47431
> Got channel MetaChannel: 8676252 -> GSSSChannel-null(1)
> - Done
> [zzhang at communicado 1MB]$ cksum input/D00001.mol2
> 1748450002 1000000 input/D00001.mol2
> [zzhang at communicado 1MB]$ cksum result/D00001.out
> 4159559983 1000000 result/D00001.out
> as you could tell from the check sum, the input and output are not the
> same. I repeated the 1MB test case, the same
> thing happened
> RunID: 20090518-1629-1gef4tm8
> Progress:
> Progress: Active:1
> Cleaning up...
> Shutting down service at https://192.41.230.11:43400
> Got channel MetaChannel: 31518612 -> GSSSChannel-null(1)
> - Done
> 2414944118 1000000 result/D00001.out
> zhao
> Mihael Hategan wrote:
> > On Mon, 2009-05-18 at 14:08 -0500, Zhao Zhang wrote:
> >>>> This is the "<filesystem provider="coaster" url="gt2://grid.myhost.org"
> >>>> />" from http://www.ci.uchicago.edu/swift/guides/userguide/coasters.php.
> >>> Right. The coaster fs provider. Glen found some data corruption with it
> >>> when transferring files larger than a few KB. So it's only somewhat
> >>> working.
> >> Has this feature been fixed?
> > No.
> >> I found it again in my data movement test
> >> on OSG site.
> > Can you be more specific?
> > In general "feature X doesn't work properly" is not very useful. I
> > recommend reading this:
> > http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
