[Swift-devel] Re: coaster features
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri May 15 11:41:23 CDT 2009
Hi, Mihael
Mihael Hategan wrote:
> On Thu, 2009-05-14 at 09:56 -0500, Zhao Zhang wrote:
>> Hi, Mihael
>> I am making a coaster test plan now, so that will be good if you could
>> help me clear what features of coaster are available in the current
>> implementation.
>> 1) Multiple coaster on 1 compute node.
>>     This feature is documented, but I am not sure if is working or not.
> Yes, this is supposed to work.
>> 2) coasterWorkerMaxwalltime
>>     This is working.
>> 3) coasterInternalIP
>>     I know this one is working, as I have already complete tests with
>> this parameter.
>>     I am not clear under what context do we need this feature. One I
>> could think of is that "using notification instead of status file". Is
>> there any other
>>     condition or any specific site requires this feature?
> I'm not sure how you know it's working if you don't know what it's
> supposed to do.
> Without this, workers use the external IP (the one the service is
> started with) to contact the service. With it, one can force the workers
> to contact a specific IP after starting. This is needed if the worker
> nodes don't generally have access to the outside of the cluster.
> This has nothing to do with notification or status files. If this
> setting is required (due to the network configuration of the cluster)
> and it is not specified, the coasters won't work at all.
Again, about this feature. How could we know that we need internal IP
for the site before we run anything on it?
Is is by experience or some tool could tell us about it? Thanks.
zhao
>> 4) coasterDataProvider
>>     This is working now.
> I don't know what that is.
>> 5) Block Allocation
>>     Is this being implemented soon, or do we decide to postpone this
>> feature?
> The priority of this item has, again, become the highest.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
