[Swift-devel] Swift-issues (PBS+NFS Cluster)
Ben Clifford
benc at hawaga.org.uk
Wed May 13 08:53:36 CDT 2009
On Mon, 11 May 2009, yizhu wrote:
> I think my next step is to write a sample swift code to check if we can let
> swift grab input files from S3, execute it, and then write the output files
> back to S3.
Swift won't be able to do this out of the box.
In the present model, you must have a shared filesystem which is
accessible from the Swift client and from each worker.
I've looked at making the Swift worker-side script, libexec_swiftwrap able
to invoke arbitrary commandlines to pull in data instead of using posix cp
or ln. You would need commandline tools to transfer a file from S3 to the
local system, and from the local system to S3. Do you have those commands?
What do they look like?
> Since each Amazon virtual node only has limited storage space( Small instance
> for 1.7GB, Large Instance for 7.5GB), we may need to use EBS(Elastic Block
> Store) to storage temp files created by swift. The EBS behaved like a hard
> disk volume and can be mounted by any virtual nodes. But here arise a problem,
> since a volume can only be attached to one instance at a time[1], so the files
> store in EBS mounted by one node won't be shared by any other nodes; we lost
> the file sharing ability which I think is a fundamental requirement for swift.
For getting a probably poorly performing prototype, the fuse idea
mentioned elsewhere seems interesting. From my understanidng, you should
be able to mount an EBS volume on the cluster head node and re-export it
using the existing NFS shared file system.
