[Swift-devel] SWIFT_JOBDIR_PATH env not passed on remote sites
    Michael Wilde
    wilde at mcs.anl.gov
    Fri May  8 17:35:40 CDT 2009
Yes, under provider-deef and Falkon the entire environment is lost. We
think that the C worker agent is not receiving or setting the environment.
- Mike
On 5/8/09 4:37 PM, Allan Espinosa wrote:
> It works with gt2.  Is this a pbs problem?
> Other provider that I am testing that it does not work is on
> provider-deef.  For my purposes, I would like to have it work under
> provider-deef and provider-pbs
> Thanks,
> -Allan
> 2009/5/8 Mihael Hategan <hategan at mcs.anl.gov>:
>> Does it also happen if you use GT2 instead of PBS?
>> On Fri, 2009-05-08 at 15:46 -0500, Allan Espinosa wrote:
>>> Hi,
>>> SWIFT_JOBDIR_PATH only works in local executions.  it looks like the
>>> environment variable is not being passed for remote job submissions:
>>> sites.xml:
>>> <config>
>>>   <pool handle="TERAPORT" sysinfo="INTEL32::LINUX">
>>>     <execution provider="pbs" url="none" />
>>>     <profile namespace="globus" key="queue">fast</profile>
>>>     <gridftp url="local://localhost" />
>>>     <workdirectory >/home/aespinosa/workflows/jobdirpath/sitedir</workdirectory>
>>>     <profile namespace="env"
>>> key="SWIFT_JOBDIR_PATH">/home/aespinosa/workflows/localnode</profile>
>>>   </pool>
>>> </config>
>>> resulting wrapper log:
>>> Progress  2009-05-08 15:33:31.258501000-0500  LOG_START
>>> _____________________________________________________________________________
>>>         Wrapper
>>> Job directory mode is: link on shared filesystem
>>> DIR=jobs/v/cat-vbmpqiaj
>>> EXEC=/bin/cat
>>> STDIN=
>>> STDOUT=061-cattwo.out
>>> STDERR=stderr.txt
>>> DIRS=
>>> INF=061-cattwo.1.in|061-cattwo.2.in
>>> OUTF=061-cattwo.out
>>> KICKSTART=
>>> ARGS=061-cattwo.1.in 061-cattwo.2.in
>>> ARGC=2
>>> Progress  2009-05-08 15:33:31.277785000-0500  CREATE_JOBDIR
>>> Created job directory: jobs/v/cat-vbmpqiaj
>>> Progress  2009-05-08 15:33:31.289956000-0500  CREATE_INPUTDIR
>>> Progress  2009-05-08 15:33:31.294467000-0500  LINK_INPUTS
>>> Linked input: /home/aespinosa/workflows/jobdirpath/sitedir/061-cattwo-20090508-1533-x71gz29g/shared/061-cattwo.1.in
>>> to jobs/v/cat-vbmpqiaj/061-cattwo.1.in
>>> Linked input: /home/aespinosa/workflows/jobdirpath/sitedir/061-cattwo-20090508-1533-x71gz29g/shared/061-cattwo.2.in
>>> to jobs/v/cat-vbmpqiaj/061-cattwo.2.in
>>> Progress  2009-05-08 15:33:31.327217000-0500  EXECUTE
>>> Moving back to workflow directory
>>> Progress  2009-05-08 15:33:31.338850000-0500  EXECUTE_DONE
>>> Job ran successfully
>>> Progress  2009-05-08 15:33:31.343910000-0500  COPYING_OUTPUTS
>>> Progress  2009-05-08 15:33:31.373251000-0500  RM_JOBDIR
>>> Progress  2009-05-08 15:33:31.383733000-0500  TOUCH_SUCCESS
>>> Progress  2009-05-08 15:33:31.398652000-0500  END
>>> the directory "localnode" is also not created.  Test peformed using
>>> 061-cattwo.  my testcase script is in ~aespinosa/workflows/jobdirpath
>>> [aespinosa at tp-login1 jobdirpath]$ ./runtest.sh
>>> Swift svn swift-r2911 cog-r2394
>>> RunID: remoterun
>>> Progress:  uninitialized:1
>>> Progress:  Active:1
>>> Final status:  Finished successfully:1
>>> Remote test FAIL
>>> RunID: localrun
>>> Progress:
>>> Local test PASS
>>> -Allan
