[Swift-devel] Re: What is best OSG site test suite ?
    Michael Wilde
    wilde at mcs.anl.gov
    Fri May  8 06:21:01 CDT 2009
Jing, Ben, thanks very much for the tips.
Jing, was site_verify.pr the older test suite was done by Jens as part
of VDS?
Also, how would you compare test_osg_ce with osg-vo-test?
Mats, do you have anything for such site testing?
Zhao, I suggest you start with test_osg_ce.
- Mike
On 5/8/09 12:43 AM, Jing Tie wrote:
> Hi Mike,
> I think others might have better tools, but I can list three here as
> possible options.
> The first one is "osg-vo-test" developed by Chris Green. It lists
> probing results for all the sites in a certain VO (e.g.
> http://www.ci.uchicago.edu/~jtie/osg-vo-test/osg_summary/2008727-19:20:43.html).
> I attached his announcement about this tool in the end of the email.
> The second one "test_osg_ce" is used by Zhengxiong, Xi and me a lot.
> It's a simple package that I developed based on site_verify.pl. It
> runs the script (check authentication, globus-job-run, gridftp, user
> directory...) for each site in a user configuration file, and print
> out the good ones. I have attached it in the email.
> The last one is RSV developed by GOC. It runs similar scripts as
> site_verify.pl by system administrators, and reports to a centralized
> server periodically. You can find it on MyOSG
> (http://myosg.grid.iu.edu/about). I think it won't be hard to setup an
> independent version for user.
> Hope it helps,
> Jing
> Email from Chris Green:
> Hi,
> I am happy to announce the first general release of an extensible
> VO-centric site testing kit, "osg-vo-test".
> To explain why you might be interested in this package, I quote from the
> overview
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Overview>
> on the package's home TWiki page
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>:
> This package is an attempt to allow /application owners/ (by which I
> mean people responsible for running an application on OSG) to
> characterize OSG sites from the point of view of being able to run your
> application. Questions can be asked of each site in multiple ways, for
> instance:
>    * Command line, eg:
>      ping my-ce.my-domain
>    * Fork job, eg:
>      globus-job-run my-ce.my-domain /usr/bin/printenv
>    * Batch job via CondorG.
>    * ReSS, the *Re*source *S*election *S*ystem.
>    * VORS, the *VO* *R*esource *S*elector.
> The results are presented primarily in the form of an HTML table
> <http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.html>
> with results columns (possibly multiple columns per test), with a link
> to more detailed information for the test.
> In addition, the summary results are available in .CSV format
> <http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.csv>
> for machine readability; a true XML format may be forthcoming if there
> is enough demand.
> The application owner can write new test modules inheriting from the
> old; for more details, see Making your own module
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Making_your_own_test_module>.
> In addition, existing tests are highly configurable and allow for the
> addition of new results columns with minimal effort; for a quick
> example, see the Getting Started
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>
> section; and also the detail
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#More_Details>
> section.
> It is extremely straightforward, for example, to test basic
> authorization at a site from the point of view of your own voms-proxy;
> and other tests are showcased in example control scripts; or provided as
> standalone test modules. The example summary page
> shows a wide range of tests of which this extensible system is capable.
> Please, visit the package's home TWiki page
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>,
> download
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Download_Source>
> the source; use
> <https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>;
> and give feedback <mailto:osg-user-group?subject=osg-vo-tests>. The aim
> is to make it easy for application owners to put together their own
> suite or suites of tests to analyze sites across the OSG from the
> perspective of the needs of their own application(s) without having to
> re-invent the wheel to interrogate all the different sources of
> information about OSG sites.
> On Thu, May 7, 2009 at 2:47 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Hi All,
>> Many of you have developed, or use, various test suites to probe the sites
>> of an OSG VO to see if basic authentication, job execution, and data
>> transfer work for a given user (cert).
>> Can you let us know, on swift-devel, what test suite you use, and what you
>> suggest that the Swift team use, as part of a Swift verification test suite
>> that reports what sites Swift does (and does not) work on?
>> In other words, once a user probes OSG to create a Swift sites file, it
>> would be useful to test if the basic services are working for the test user,
>> before testing at a higher level through Swift.
>> Thanks,
>> Mike
