[Swift-devel] Re: What is best OSG site test suite ?
Jing Tie
tiejing at gmail.com
Fri May 8 00:43:00 CDT 2009
Hi Mike,
I think others might have better tools, but I can list three here as
possible options.
The first one is "osg-vo-test" developed by Chris Green. It lists
probing results for all the sites in a certain VO (e.g.
http://www.ci.uchicago.edu/~jtie/osg-vo-test/osg_summary/2008727-19:20:43.html).
I attached his announcement about this tool in the end of the email.
The second one "test_osg_ce" is used by Zhengxiong, Xi and me a lot.
It's a simple package that I developed based on site_verify.pl. It
runs the script (check authentication, globus-job-run, gridftp, user
directory...) for each site in a user configuration file, and print
out the good ones. I have attached it in the email.
The last one is RSV developed by GOC. It runs similar scripts as
site_verify.pl by system administrators, and reports to a centralized
server periodically. You can find it on MyOSG
(http://myosg.grid.iu.edu/about). I think it won't be hard to setup an
independent version for user.
Hope it helps,
Jing
Email from Chris Green:
I am happy to announce the first general release of an extensible
VO-centric site testing kit, "osg-vo-test".
To explain why you might be interested in this package, I quote from the
overview
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Overview>
on the package's home TWiki page
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>:
This package is an attempt to allow /application owners/ (by which I
mean people responsible for running an application on OSG) to
characterize OSG sites from the point of view of being able to run your
application. Questions can be asked of each site in multiple ways, for
instance:
* Command line, eg:
ping my-ce.my-domain
* Fork job, eg:
globus-job-run my-ce.my-domain /usr/bin/printenv
* Batch job via CondorG.
* ReSS, the *Re*source *S*election *S*ystem.
* VORS, the *VO* *R*esource *S*elector.
The results are presented primarily in the form of an HTML table
<http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.html>
with results columns (possibly multiple columns per test), with a link
to more detailed information for the test.
In addition, the summary results are available in .CSV format
<http://user-support.opensciencegrid.org/osg-vo-tests/site-test-examples/fermilab/20070927_004422/fermilab_summary.csv>
for machine readability; a true XML format may be forthcoming if there
is enough demand.
The application owner can write new test modules inheriting from the
old; for more details, see Making your own module
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Making_your_own_test_module>.
In addition, existing tests are highly configurable and allow for the
addition of new results columns with minimal effort; for a quick
example, see the Getting Started
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>
section; and also the detail
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#More_Details>
section.
It is extremely straightforward, for example, to test basic
authorization at a site from the point of view of your own voms-proxy;
and other tests are showcased in example control scripts; or provided as
standalone test modules. The example summary page
shows a wide range of tests of which this extensible system is capable.
Please, visit the package's home TWiki page
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests>,
download
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Download_Source>
the source; use
<https://twiki.grid.iu.edu/twiki/bin/view/UserGroup/OsgVoSiteTests#Getting_Started>;
and give feedback <mailto:osg-user-group?subject=osg-vo-tests>. The aim
is to make it easy for application owners to put together their own
suite or suites of tests to analyze sites across the OSG from the
perspective of the needs of their own application(s) without having to
re-invent the wheel to interrogate all the different sources of
information about OSG sites.
On Thu, May 7, 2009 at 2:47 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Hi All,
> Many of you have developed, or use, various test suites to probe the sites
> of an OSG VO to see if basic authentication, job execution, and data
> transfer work for a given user (cert).
> Can you let us know, on swift-devel, what test suite you use, and what you
> suggest that the Swift team use, as part of a Swift verification test suite
> that reports what sites Swift does (and does not) work on?
> In other words, once a user probes OSG to create a Swift sites file, it
> would be useful to test if the basic services are working for the test user,
> before testing at a higher level through Swift.
> Thanks,
> Mike
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090508/c304426c/attachment.zip>
