[Swift-devel] Using multiple "optional" providers
    Ben Clifford
    benc at hawaga.org.uk
    Fri May  8 02:28:12 CDT 2009
Slightly strange things happen when turning options on and off and running
redist. For example, if provider-ln is already built, it appears in your
dist/ directory even if you don't enable it in the present build. I think
the same will happen for deef. You might be encountering effects like
that.
On Fri, 8 May 2009, Allan Espinosa wrote:
> I tried including provider-deef and provider-ln through
> $ant -Dwith-provider-deef -Dwith-provider-ln redist
> but only provider-deef is being built (or provider-ln if it was the one
> defined first).  So I set it to arbitrary values
> $ant -Dwith-provider-deef=1 -Dwith-provider-ln=1 redist
> and it works!
> Works for other combinations of these optional providers like wonky and
> condor
> -Allan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
