[Swift-devel] Re: Swift-issues (PBS+NFS Cluster)
    Ben Clifford
    benc at hawaga.org.uk
    Thu May  7 02:28:14 CDT 2009
On Thu, 7 May 2009, Ben Clifford wrote:
> I was expecting you to be running directly from Swift to PBS, not using
> GRAM in between.
Separately from running with GRAM, you can submit from Swift directly to
PBS from any of your cluster nodes that you can use PBS's qsub/qstat
commands. That will remove one layer of complexity from your setup,
although it will require you to run Swift from within your cluster rather
than from some other host.
