[Swift-devel] Re: Swift-issues (PBS+NFS Cluster)
    Ben Clifford
    benc at hawaga.org.uk
    Thu May  7 02:21:20 CDT 2009
>     <execution
> url="https://tp-x001.ci.uchicago.edu:8443/wsrf/services/ManagedJobFactoryService"
> jobManager="PBS" provider="gt4" />
I was expecting you to be running directly from Swift to PBS, not using
GRAM in between.
Please check that you can run GRAM4 jobs using globusrun-ws, something
like:
globusrun-ws -submit -F tp-x001.ci.uchicago.edu -Ft PBS -c /bin/hostname
This command should run through several stages and return you to the
command prompt. Please paste the output of that there.
