[Swift-devel] Re: condor-G issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue May  5 14:16:24 CDT 2009
I got it, it is because the condor version on ci network.
zhao
Zhao Zhang wrote:
> Hi, All
> I am running test on grid sites with condor-G provider, but failed on
> AGLT2.xml. I am attaching the sites.xml and the standard output.
> Again as we did yesterday, all gram logs from  that site could be
> found at
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/condor-g-log
> Thanks.
> zhao
> [zzhang at communicado condor-g]$ cat AGLT2.xml
> <config>
>  <!-- AGLT2 -->
>  <pool handle="AGLT2" >
>    <gridftp  url="gsiftp://gate02.grid.umich.edu/" />
>    <execution  provider="condor" />
>    <workdirectory >/atlas/data08/OSG/DATA/osg/tmp/AGLT2</workdirectory>
>    <profile namespace="globus" key="jobType">grid</profile>
>    <profile namespace="globus" key="gridResource">gt2
> gate02.grid.umich.edu/jobmanager-Condor</profile>
>  </pool>
> </config>
> [zzhang at communicado condor-g]$ globus-job-run gate02.grid.umich.edu
> /usr/bin/id
> uid=789087(osg) gid=55682(osg) groups=55682(osg)
> [zzhang at communicado condor-g]$ cd ..
> [zzhang at communicado sites]$ ./run-site condor-g/AGLT2.xml
> testing site configuration: condor-g/AGLT2.xml
> Removing files from previous runs
> Running test 061-cattwo at Tue May 5 12:45:43 CDT 2009
> Swift svn swift-r2896 cog-r2392
> RunID: 20090505-1245-czyer1rc
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Failed to transfer wrapper log from
> 061-cattwo-20090505-1245-czyer1rc/info/m on AGLT2
> 061-cattwo-20090505-1245-czyer1rc/info/o on AGLT2
> Progress: Failed but can retry:1
> 061-cattwo-20090505-1245-czyer1rc/info/q on AGLT2
> Progress:  Failed:1
> Execution failed:
>        Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: AGLT2
> Directory: 061-cattwo-20090505-1245-czyer1rc/jobs/q/cat-qygamdaj
> stderr.txt:
> stdout.txt:
> Caused by:
>        Cannot submit job: Could not submit job (condor_submit reported
> an exit code of 1). no error output
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
