[Swift-devel] condor-G issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue May  5 13:07:41 CDT 2009
Hi, All
I am running test on grid sites with condor-G provider, but failed on
AGLT2.xml. I am attaching the sites.xml and the standard output.
Again as we did yesterday, all gram logs from  that site could be found
at /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/condor-g-log
Thanks.
zhao
[zzhang at communicado condor-g]$ cat AGLT2.xml
<config>
  <!-- AGLT2 -->
  <pool handle="AGLT2" >
    <gridftp  url="gsiftp://gate02.grid.umich.edu/" />
    <execution  provider="condor" />
    <workdirectory >/atlas/data08/OSG/DATA/osg/tmp/AGLT2</workdirectory>
    <profile namespace="globus" key="jobType">grid</profile>
    <profile namespace="globus" key="gridResource">gt2
gate02.grid.umich.edu/jobmanager-Condor</profile>
  </pool>
</config>
[zzhang at communicado condor-g]$ globus-job-run gate02.grid.umich.edu
/usr/bin/id
uid=789087(osg) gid=55682(osg) groups=55682(osg)
[zzhang at communicado condor-g]$ cd ..
[zzhang at communicado sites]$ ./run-site condor-g/AGLT2.xml
testing site configuration: condor-g/AGLT2.xml
Removing files from previous runs
Running test 061-cattwo at Tue May 5 12:45:43 CDT 2009
Swift svn swift-r2896 cog-r2392
RunID: 20090505-1245-czyer1rc
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Failed to transfer wrapper log from
061-cattwo-20090505-1245-czyer1rc/info/m on AGLT2
061-cattwo-20090505-1245-czyer1rc/info/o on AGLT2
Progress: Failed but can retry:1
061-cattwo-20090505-1245-czyer1rc/info/q on AGLT2
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: AGLT2
Directory: 061-cattwo-20090505-1245-czyer1rc/jobs/q/cat-qygamdaj
stderr.txt:
stdout.txt:
Caused by:
        Cannot submit job: Could not submit job (condor_submit reported
an exit code of 1). no error output
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
