[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon May  4 16:32:23 CDT 2009
So I got the following info
[zzhang at communicado uj]$ globus-job-run osg-ce.grid.uj.ac.za
/usr/bin/qstat -q
server: gridvm
Queue            Memory CPU Time Walltime Node  Run Que Lm  State
medium             --   02:00:00    --      --    0   0 50   E R
atlas              --      --    02:00:00   --    0   0 --   E R
gilda              --   02:00:00    --      --    0   0 --   E R
batch              --      --    01:00:00   --    0   0 --   E R
small              --   00:20:00    --      --    0   0 50   E R
default            --      --       --      --    0   0 --   E R
long               --   12:00:00    --      --    0   0 20   E R
verylong           --   72:00:00    --      --    0   0 10   E R
                                                   0     0
Then I used the default queue, now job is running. Thanks!
zhao
Mihael Hategan wrote:
> gram_job_mgr_10273.log:
> Mon May  4 20:59:33 2009 JM_SCRIPT: qsub returned
> Mon May  4 20:59:33 2009 JM_SCRIPT: qsub stderr qsub: Job exceeds queue
> resource limits MSG=cannot satisfy queue max walltime requirement
> Find out what queues are on that machine (qstat -q), and change
> appropriately. That or set the proper coasterWorkerMaxwalltime.
> On Mon, 2009-05-04 at 15:57 -0500, Zhao Zhang wrote:
>> Hey, Here are all of them:
>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/uj    :-)
>> zhao
>>> On Mon, 2009-05-04 at 15:07 -0500, Zhao Zhang wrote:
>>>> This one?
>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_18272.log
>>> Nope. I suggest copying them all, and I'll look for the right one.
>>>> zhao
>>>>> On Mon, 2009-05-04 at 15:02 -0500, Zhao Zhang wrote:
>>>>>> I also pulled out the coaster log in the same directory. Then what shall
>>>>>> we do with this error?
>>>>> Was that the only gram log? What I suspect is that there is another gram
>>>>> log which is more relevant.
>>>>>> zhao
>>>>>>> On Mon, 2009-05-04 at 14:46 -0500, Zhao Zhang wrote:
>>>>>>>> Ha, I got it.
>>>>>>>> It is at CI network:
>>>>>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_22265.log
>>>>>>> There you go :)
>>>>>>> I'm not sure this is the right log though. This is the one from the job
>>>>>>> that was used to start the coaster service, and it shows a different
>>>>>>> error (155 - stageout failure).
