[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May  4 16:05:46 CDT 2009
gram_job_mgr_10273.log:
Mon May  4 20:59:33 2009 JM_SCRIPT: qsub returned
Mon May  4 20:59:33 2009 JM_SCRIPT: qsub stderr qsub: Job exceeds queue
resource limits MSG=cannot satisfy queue max walltime requirement
Find out what queues are on that machine (qstat -q), and change
appropriately. That or set the proper coasterWorkerMaxwalltime.
On Mon, 2009-05-04 at 15:57 -0500, Zhao Zhang wrote:
> Hey, Here are all of them:
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/uj    :-)
> zhao
> Mihael Hategan wrote:
> > On Mon, 2009-05-04 at 15:07 -0500, Zhao Zhang wrote:
> >> This one?
> >> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_18272.log
> > Nope. I suggest copying them all, and I'll look for the right one.
> >> zhao
> >>> On Mon, 2009-05-04 at 15:02 -0500, Zhao Zhang wrote:
> >>>> I also pulled out the coaster log in the same directory. Then what shall
> >>>> we do with this error?
> >>> Was that the only gram log? What I suspect is that there is another gram
> >>> log which is more relevant.
> >>>> zhao
> >>>>> On Mon, 2009-05-04 at 14:46 -0500, Zhao Zhang wrote:
> >>>>>> Ha, I got it.
> >>>>>> It is at CI network:
> >>>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_22265.log
> >>>>> There you go :)
> >>>>> I'm not sure this is the right log though. This is the one from the job
> >>>>> that was used to start the coaster service, and it shows a different
> >>>>> error (155 - stageout failure).
