[Swift-devel] Re: coaster issue
    Mats Rynge
    rynge at renci.org
    Mon May  4 10:51:18 CDT 2009
Zhao Zhang wrote:
> Hi, Mats
> But I still could not run it.
Today you are mapped to the OSG VO. We need to disable on you the VOs
you do not want to run as, and make sure only one VO is left to use.
For your testing, I suggest you stay with the OSG VO, and leave the
Engagement VO and OSGEDU VO.
> [zzhang at communicado sites]$ ./run-site coaster/renci-engage-coaster.xml
> testing site configuration: coaster/renci-engage-coaster.xml
> Removing files from previous runs
> Running test 061-cattwo at Mon May 4 10:13:57 CDT 2009
> Swift svn swift-r2896 cog-r2392
> RunID: 20090504-1013-fvsq25zf
> Progress:
> Progress:  Initializing site shared directory:1
> Execution failed:
>        Could not initialize shared directory on renci-engage
> Caused by:
>        org.globus.cog.abstraction.impl.file.FileResourceException:
> Cannot create directory
> /nfs/osg-data/osgedu/benc/swift/061-cattwo-20090504-1013-fvsq25zf
> Caused by:
>        Server refused performing the request. Custom message: Server
> refused creating directory (error code 1) [Nested exception message:
> Custom message: Unexpected reply: 500-Command failed :
> globus_gridftp_server_file.c:globus_l_gfs_file_mkdir:554:
> 500-System error in mkdir: Permission denied
> 500-A system call failed: Permission denied
> 500 End.]
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> and my sites.xml is
> <config>
>  <pool handle="renci-engage" >
>    <gridftp  url="gsiftp://belhaven-1.renci.org/" />
>    <!-- <filesystem provider="coaster" url="gt2://belhaven-1.renci.org"
>     <execution provider="coaster" url="belhaven-1.renci.org"
> jobManager="gt2:gt2:condor" />
>     <workdirectory >/nfs/osg-data/osgedu/benc/swift</workdirectory>
> <profile namespace="globus" key="coasterInternalIP">192.168.1.11</profile>
> </pool>
> </config>
> zhao
> Mats Rynge wrote:
>> Zhao Zhang wrote:
>>> Hi, Ben
>>> This means if I am mapped to osgedu VO, I could not run anything on
>>> the renci site defined in renci-engage-coaster.xml, right?
>> The RENCI site supports osgedu, so it should work with your existing
>> credential.
Mats Rynge
Renaissance Computing Institute <http://www.renci.org>
