[Swift-devel] Re: coaster issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon May  4 10:15:13 CDT 2009
Hi, Mats
But I still could not run it.
[zzhang at communicado sites]$ ./run-site coaster/renci-engage-coaster.xml
testing site configuration: coaster/renci-engage-coaster.xml
Removing files from previous runs
Running test 061-cattwo at Mon May 4 10:13:57 CDT 2009
Swift svn swift-r2896 cog-r2392
RunID: 20090504-1013-fvsq25zf
Progress:
Progress:  Initializing site shared directory:1
Execution failed:
        Could not initialize shared directory on renci-engage
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException:
Cannot create directory
/nfs/osg-data/osgedu/benc/swift/061-cattwo-20090504-1013-fvsq25zf
Caused by:
        Server refused performing the request. Custom message: Server
refused creating directory (error code 1) [Nested exception message:
Custom message: Unexpected reply: 500-Command failed :
globus_gridftp_server_file.c:globus_l_gfs_file_mkdir:554:
500-System error in mkdir: Permission denied
500-A system call failed: Permission denied
500 End.]
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
and my sites.xml is
<config>
  <pool handle="renci-engage" >
    <gridftp  url="gsiftp://belhaven-1.renci.org/" />
    <!-- <filesystem provider="coaster" url="gt2://belhaven-1.renci.org"
     <execution provider="coaster" url="belhaven-1.renci.org"
jobManager="gt2:gt2:condor" />
     <workdirectory >/nfs/osg-data/osgedu/benc/swift</workdirectory>
<profile namespace="globus" key="coasterInternalIP">192.168.1.11</profile>
</pool>
</config>
zhao
Mats Rynge wrote:
> Zhao Zhang wrote:
>> Hi, Ben
>> This means if I am mapped to osgedu VO, I could not run anything on
>> the renci site defined in renci-engage-coaster.xml, right?
> The RENCI site supports osgedu, so it should work with your existing
> credential.
