[Swift-devel] printing and library functions
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Mar 24 22:00:02 CDT 2009
[was: Re: [Swift-devel] could we set the job sequence without a file
dependency?]
[digression on]
 From what Ive done with oops over the past month I observe a need to
print the status of the workflow as it proceeds.
I guess thats a kind of "debugging" - watching to make sure a workflow
is making progress.
I *used* to tail the debug log; then I started tailing that log to watch
and count specific status messages. Now Ive taken to entirely watching
just stdout, and only looking in the log when things fail and the output
file doesnt clearly say why. I feel its a good step forward that I can
do this.
But users will, I believe, want some way beyond just the periodic status
line to show how their script is progressing.  I used trace, which is
OK. I think this need will grow as I hand oops over the people who will
be running it to do science (and by the way, thanks to all of you that
is happening as we speak!).
This comment, btw, is not on the topic of "seq{}", but rather on the
need for output primitives.
So, while we're on this topic and digressing:
I often missed various string and data handling operations in Swift. In
a few points of developing oops, I was delighted to find that I could
implement almost any library function I wanted (including string
functions like sprintf/fprintf, intToStr(), etc, using a 2-step call: an
app to call the external function, and if needed a proc to wrap it and
use readData() or readdata2() to extract back the return value(s).
I turned out to be pretty reasonable to define a nice sprintf at the
moment by passing a varying number of arguments as an array of strings
using an array constructor:
[ s1, s1, itos(i1), ftos(f1), btos(b1) ]
using one layer of primitives to convert all objects to strings, and
then passing the string array to sprintf(), and back to trace().
Discovering how to do this eliminated a request I had long been
repressing for "easier to implement built-in functions".
The fact that readdata accepted a file in addition to a file name was
critical.
A few things that do come to mind on this, to permit more flexible (or
aesthetic) library functions, are:
- varying length arg lists (or)
- arrays of type Object (ie heterogeneous arrays)
- \ escapes in strings (\n \t etc)
- sizeof(array)
- isSet() etc: See if a var is set or not. cant recall now where I
wanted this, need to check my notes. Not very important, I think this
was to hack around some other issue, cant recall what. Im sure its a
functional and synchronization no-no.
One might define the first two in various ways related to each other.
So out of all these things, the only one that might be nice to do sooner
is the \ escapes in strings, iff thats easy.
Just thought I would toss those out in case others have seen similar
needs and see easy ways to implement them.
Im excited about the prospects of seeing a Swift library grow. I'll try
to package up the few functions Ive played with to spark some ideas and
library development. We should start batting around ideas for libraries,
and for naming, etc, but a simple include mechanism for now will get us far.
- Mike
(the astute will notice that I have neglected to set [digression off].
That may or may not have been intensional... ;)
On 3/24/09 4:37 PM, Ben Clifford wrote:
> On Tue, 24 Mar 2009, Ian Foster wrote:
>> This was the case in PCN when people were trying to do printf-like output. So
>> you introduced a version of printf that bound a variable when it was done, and
>> then wrote something like:
>> BUT -- maybe we don't really do output like this in Swift programs (I don't
>> think it is common, is it)?
> Its not common to do "meat output" like that, no - all of that comes from
> procedures which generate files, which tend to not need sequencing of
> output.
> Most of what you've talked about seems debugging oriented - none of the
> debugging I've done with people has really felt like I've wanted that kind
> of sequence operator. But I think some debugging-oriented something (be it
> language features, runtime options, something) would be useful - but its
> not clear to me what.
