[Swift-devel] Re: lots of variable not found
    Ben Clifford
    benc at hawaga.org.uk
    Sun Mar 22 09:18:59 CDT 2009
I just moved the nmi per-commit build to another platform and on the first
build there I saw this:
java.util.ConcurrentModificationException
	at java.util.HashMap$HashIterator.nextEntry(HashMap.java:841)
	at java.util.HashMap$KeyIterator.next(HashMap.java:877)
	at
org.globus.cog.karajan.arguments.ArgUtil.initializeChannelBuffers(ArgUtil.java:191)
	at
org.globus.cog.karajan.workflow.nodes.Parallel.initializeChannelBuffers(Parallel.java:57)
	at
org.globus.cog.karajan.workflow.nodes.Parallel.executeChildren(Parallel.java:36)
	at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
	at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
	at
org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
	at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
	at
org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
running 066-many with swift r2729 and cog r2333.
The 066-many test does not seem to be doing very well these days.
I'm running that test a few more times to see how reproducible it is.
http://nmi-s005.cs.wisc.edu:80/nmi/index.php?page=results/runDetails&runid=140151&opt_project=swift
