[Swift-devel] How does swift know if a task is successful
Zhao Zhang
zhaozhang at uchicago.edu
Tue Mar 17 23:04:59 CDT 2009
Hi, Sarah
skenny at uchicago.edu wrote:
> hey zhao, did you get this to work?
Not yet, I am still working on it.
> was thinking i might try
> it on ranger, but i was wondering if you also then have to
> hack something else to prevent swift from cleaning up your
> work directory?
I think to prevent swift cleaning up work dir is just an option in
swift.properties.
> that is, i assume you actually DO want the
> output, you just don't want to have to wait for the stageouts (?)
exactly, currently, we are building a collective IO system on BGP, so
CIO will take
care of stage out results.
zhao
> ---- Original message ----
>> Date: Tue, 17 Mar 2009 13:40:30 -0500
>> From: Mihael Hategan <hategan at mcs.anl.gov>
>> Subject: Re: [Swift-devel] How does swift know if a task is
> successful
>> To: Zhao Zhang <zhaozhang at uchicago.edu>
>> Cc: swift-devel <swift-devel at ci.uchicago.edu>
>> On Tue, 2009-03-17 at 13:36 -0500, Zhao Zhang wrote:
>>> Hi, Mihael
>>> I commented the following lines
>>> /*dir:make(ldir)
>>> restartOnError(".*", 2
>>> task:transfer(srchost=host, srcfile=bname,
>>> srcdir=rdir, destdir=ldir, desthost=dhost,
> destprovider=provider)
>> Did you modify this file in dist/?/libexec? If not, did you
> re-compile
>> swift after the modification?
>> Put an echo or a log message in place, to see if your change
> is picked
>> up by swift next time.
>>> Then I modified wrapper.sh to not to copy output file back,
> but I still
>>> got an error.
>>> The log file is at
> http://www.ci.uchicago.edu/~zzhang/first-20090317-1327-oqgttus8.log
>>> Thanks
>>> zhao
>>> zzhang at login6.surveyor:~/new_dock6> ./run_swift_ssh.sh 1117
> 64 first.swift
>>> waiting for at least 64 nodes to register before submitting
> workload...
>>> waiting to find at least 1 services in file
> /home/falkon/users/zzhang/1117/config/Client-service-URIs.config...
>>> all done, file has found at least 1 services
>>> found at least 64 registered, submitting workload...
>>> Swift svn swift-r2676 (swift modified locally) cog-r2305
>>> RunID: 20090317-1327-oqgttus8
>>> Progress:
>>> Progress: Selecting site:1 Stage in:1
>>> Progress: Submitting:1 Submitted:1
>>> Progress: Submitted:1 Failed but can retry:1
>>> Failed to transfer wrapper log from
>>> first-20090317-1327-oqgttus8/info/b/n/bgp000
>>> Progress: Submitted:1 Active:1
>>> first-20090317-1327-oqgttus8/info/e/n/bgp000
>>> first-20090317-1327-oqgttus8/info/g/n/bgp000
>>> Execution failed:
>>> Exception in echo:
>>> Arguments: [Hello, world!]
>>> Host: bgp000
>>> Directory: first-20090317-1327-oqgttus8/jobs/g/n/echo-gnlq238j
>>> stderr.txt:
>>> stdout.txt:
>>> Caused by:
>>> Cannot transfer
>>> "/tmp/first-20090317-1327-oqgttus8/shared/hello.txt" to
>>> "/gpfs/home/zzhang/new_dock6/./hello.txt"
>>> Caused by:
>>> No such file
>>> Mihael Hategan wrote:
>>>> On Tue, 2009-03-17 at 12:23 -0500, Zhao Zhang wrote:
>>>>> Hi, Mihael
>>>>> yes, can I do that?
>>>> You should know this by now:
>>>> in vdl-int.k, in doStageout, comment out the
> task:transfer invocation
>>>> (and dir:make).
>>>>> zhao
>>>>>> On Tue, 2009-03-17 at 12:14 -0500, Zhao Zhang wrote:
>>>>>>> Here comes another question, is there any place that I
> could set to
>>>>>>> disable swift's waiting for data feature?
>>>>>> Do you mean disable the stage-outs?
>>>>>>> Or is there any way for me to cheat swift that the
> data is already
>>>>>>> there? thanks.
>>>>>>> zhao
>>>>>>>> On Fri, 2009-03-13 at 17:07 -0500, Zhao Zhang wrote:
>>>>>>>>> Hi, All
>>>>>>>>> I have a question on how swift knows if a task is
> successful.
>>>>>>>>> In my case, I am using a status notification instead
> of a status file.
>>>>>>>>> So my question is is this status notification the
> only thing swift is
>>>>>>>>> waiting for, or is swift also waiting for the output
> data to appear to
>>>>>>>>> say that a job is successful?
>>>>>>>> Once the job is done, swift will attempt to stage out
> all the files that
>>>>>>>> it expects the job to have produced.
>>>>>>>> Should one of those files not be there, there will be
> failures.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
