[Swift-devel] null pointer exception from nested loops
Mihael Hategan hategan at mcs.anl.gov
Tue Mar 17 17:10:02 CDT 2009
Looks like it might be the nested procedure call interacting badly with
readData.
On Tue, 2009-03-17 at 17:02 -0500, Michael Wilde wrote:
> OK, I think this is it:
> The following script *works* with the commented out code and fails with
> the currently enabled alternative statement:
> type file;
> app (file editedParams) setTemps ( file inParams )
>    sed "-e" "s/@DTI@/123/" @inParams stdout=@editedParams;
> file inParams<single_file_mapper; file="params.tloop" >;
> /* works:
> file o<"pout">;
> o = setTemps(inParams);
> string config [] = readData(o);
> /* Fails: */
> string config [] = readData( setTemps(inParams ) );
> trace(0,config[0]);
> trace(1,config[1]);
> trace(2,config[2]);
> So readData is indeed happy to take a file-value var as an arg but not a
> file-valued expression (procedure return in this case).
> On 3/17/09 4:46 PM, Michael Wilde wrote:
> > I got the error narrowed down to this example:
> > type file;
> >   echo @inParams stdout=@editedParams;
> > trace(0,config[0]);
> > trace(1,config[1]);
> > trace(2,config[2]);
> > params.tloops contains:
> > DEFAULT_INIT_TEMP_=_ at DTI@
> > TEMP_UPDATE_INTERVAL_=_ at TUI@
> > KILL_TIME_=_3
> > MAX_NUMBER_OF_ANNEALING_STEPS_=_0
> > In other code, readData() seemed happy to take a file *or* a filename
> > string as input, but I wonder if it was not as happy as it seemed.
> > I'd been taking advantage of the flexibility with good results (luck?)
> > so far, though.
> > On 3/17/09 4:25 PM, Michael Wilde wrote:
> >> The log contains this just before the NPE, including the suspicious
> >> message: WARN  FlowNode Ex098:
> >> Thats giving me a clue as to the offending statements.
> >> 2009-03-17 16:20:34,723-0500 INFO  AbstractDataNode Adding handle
> >> listener "F/org.griphyn.vdl.mapping.DataNode identifier
> >> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090\
> >> 317-1620-e1n1bz3g:720000000071 type SecSeq with no value at
> >> dataset=secseq path=[0] (not closed)" to
> >> "org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu,\
> >> 2008:swift:dataset:20090317-1620-e1n1bz3g:720000000071 type SecSeq
> >> with no value at dataset=secseq path=[0] (not closed)"
> >> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode closed
> >> org.griphyn.vdl.mapping.RootDataNode identifier
> >> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz\
> >> 3g:720000000092 type string value=s/@DIT@/10/ dataset=unnamed
> >> SwiftScript value (closed)
> >> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode ROOTPATH
> >> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz3g:720000000092
> >> path=$
> >> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode VALUE
> >> VALUE=s/@DIT@/10/
> >> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode closed
> >> 3g:720000000093 type string value=s/@TUI@/1/ dataset=unnamed
> >> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode ROOTPATH
> >> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz3g:720000000093
> >> path=$
> >> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode VALUE
> >> VALUE=s/@TUI@/1/
> >> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode closed
> >> 3g:720000000094 type string value=params.tloop dataset=unnamed
> >> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode ROOTPATH
> >> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz3g:720000000094
> >> path=$
> >> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode VALUE
> >> VALUE=params.tloop
> >> 2009-03-17 16:20:34,727-0500 WARN  FlowNode Ex098
> >> java.lang.NullPointerException
> >>         at
> >> org.griphyn.vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:285)
> >>         at
> >> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:201)
> >>         at
> >> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:182)
> >>         at
> >> org.griphyn.vdl.karajan.lib.swiftscript.FileName.function(FileName.java:19)
> >>         at
> >> org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:67)
> >> On 3/17/09 4:17 PM, Michael Wilde wrote:
> >>> It seems not related to scale or Falkon.
> >>> It occurs when running on localhost (but on bgp) and when I cut all
> >>> the loops down to a single iteration.
> >>> I'm still debugging.
> >>> On 3/17/09 4:07 PM, Michael Wilde wrote:
> >>>> I just expanded my oops protein folding script to add another level
> >>>> of parameter sweep. This script is getting pretty complex now (at
> >>>> least, for a swift script).
> >>>> I got the following npe on my first two tries. Im going to start
> >>>> debugging, but any clues as to the cause would be helpful.
> >>>> The outer loops are:
> >>>> main()
> >>>>   string protein[] = readData(@arg("plist"));
> >>>>   string startTemp[] = ["10","20"];
> >>>>   string tempUpdate[] = ["1","2","3"];
> >>>>   foreach p in protein {
> >>>>     foreach st in startTemp {
> >>>>       foreach tu in tempUpdate {
> >>>>         doRoundSet(p,st,tu);
> >>>> There are two levels of inner loops further down below doRoundSet().
> >>>> The script, output, command line args and log are in:
> >>>> http://ww.ci.uchicago.edu/~wilde/swift3.tar.gz
> >>>> I suspect it will take a while to narrow the cause to a simpler test
> >>>> case thats easy tp reproduce without a lot of setup.
> >>>> I'll try on a vanilla swift on local execution; this is on bgp with
> >>>> Falkon.
> >>>> Thanks.
> >>>> Progress:  uninitialized:1 Selecting site:2
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 7
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 2
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 8
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 0
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 5
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 9
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 1
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 6
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 3
> >>>> SwiftScript trace: T1af7, Round, 0, Sim, 4
> >>>> Ex098
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:296)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
> >>>>     at
> >>>>     at
> >>>>     at
> >>>> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> >>>> Execution failed:
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>> Ex098
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>>     at
> >>>> _______________________________________________
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
