[Swift-devel] null pointer exception from nested loops
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Mar 17 17:02:31 CDT 2009
OK, I think this is it:
The following script *works* with the commented out code and fails with
the currently enabled alternative statement:
type file;
app (file editedParams) setTemps ( file inParams )
   sed "-e" "s/@DTI@/123/" @inParams stdout=@editedParams;
file inParams<single_file_mapper; file="params.tloop" >;
/* works:
file o<"pout">;
o = setTemps(inParams);
string config [] = readData(o);
/* Fails: */
string config [] = readData( setTemps(inParams ) );
trace(0,config[0]);
trace(1,config[1]);
trace(2,config[2]);
So readData is indeed happy to take a file-value var as an arg but not a
file-valued expression (procedure return in this case).
On 3/17/09 4:46 PM, Michael Wilde wrote:
> I got the error narrowed down to this example:
> type file;
>   echo @inParams stdout=@editedParams;
> trace(0,config[0]);
> trace(1,config[1]);
> trace(2,config[2]);
> params.tloops contains:
> DEFAULT_INIT_TEMP_=_ at DTI@
> TEMP_UPDATE_INTERVAL_=_ at TUI@
> KILL_TIME_=_3
> MAX_NUMBER_OF_ANNEALING_STEPS_=_0
> In other code, readData() seemed happy to take a file *or* a filename
> string as input, but I wonder if it was not as happy as it seemed.
> I'd been taking advantage of the flexibility with good results (luck?)
> so far, though.
> On 3/17/09 4:25 PM, Michael Wilde wrote:
>> The log contains this just before the NPE, including the suspicious
>> message: WARN  FlowNode Ex098:
>> Thats giving me a clue as to the offending statements.
>> 2009-03-17 16:20:34,723-0500 INFO  AbstractDataNode Adding handle
>> listener "F/org.griphyn.vdl.mapping.DataNode identifier
>> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090\
>> 317-1620-e1n1bz3g:720000000071 type SecSeq with no value at
>> dataset=secseq path=[0] (not closed)" to
>> "org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uchicago.edu,\
>> 2008:swift:dataset:20090317-1620-e1n1bz3g:720000000071 type SecSeq
>> with no value at dataset=secseq path=[0] (not closed)"
>> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode closed
>> org.griphyn.vdl.mapping.RootDataNode identifier
>> tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz\
>> 3g:720000000092 type string value=s/@DIT@/10/ dataset=unnamed
>> SwiftScript value (closed)
>> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode ROOTPATH
>> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz3g:720000000092
>> path=$
>> 2009-03-17 16:20:34,724-0500 INFO  AbstractDataNode VALUE
>> VALUE=s/@DIT@/10/
>> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode closed
>> 3g:720000000093 type string value=s/@TUI@/1/ dataset=unnamed
>> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode ROOTPATH
>> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz3g:720000000093
>> path=$
>> 2009-03-17 16:20:34,725-0500 INFO  AbstractDataNode VALUE
>> VALUE=s/@TUI@/1/
>> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode closed
>> 3g:720000000094 type string value=params.tloop dataset=unnamed
>> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode ROOTPATH
>> dataset=tag:benc at ci.uchicago.edu,2008:swift:dataset:20090317-1620-e1n1bz3g:720000000094
>> path=$
>> 2009-03-17 16:20:34,726-0500 INFO  AbstractDataNode VALUE
>> VALUE=params.tloop
>> 2009-03-17 16:20:34,727-0500 WARN  FlowNode Ex098
>> java.lang.NullPointerException
>>         at
>> org.griphyn.vdl.karajan.lib.VDLFunction.leafFileName(VDLFunction.java:285)
>>         at
>> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:201)
>>         at
>> org.griphyn.vdl.karajan.lib.VDLFunction.filename(VDLFunction.java:182)
>>         at
>> org.griphyn.vdl.karajan.lib.swiftscript.FileName.function(FileName.java:19)
>>         at
>> org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:67)
>> On 3/17/09 4:17 PM, Michael Wilde wrote:
>>> It seems not related to scale or Falkon.
>>> It occurs when running on localhost (but on bgp) and when I cut all
>>> the loops down to a single iteration.
>>> I'm still debugging.
>>> On 3/17/09 4:07 PM, Michael Wilde wrote:
>>>> I just expanded my oops protein folding script to add another level
>>>> of parameter sweep. This script is getting pretty complex now (at
>>>> least, for a swift script).
>>>> I got the following npe on my first two tries. Im going to start
>>>> debugging, but any clues as to the cause would be helpful.
>>>> The outer loops are:
>>>> main()
>>>>   string protein[] = readData(@arg("plist"));
>>>>   string startTemp[] = ["10","20"];
>>>>   string tempUpdate[] = ["1","2","3"];
>>>>   foreach p in protein {
>>>>     foreach st in startTemp {
>>>>       foreach tu in tempUpdate {
>>>>         doRoundSet(p,st,tu);
>>>> There are two levels of inner loops further down below doRoundSet().
>>>> The script, output, command line args and log are in:
>>>> http://ww.ci.uchicago.edu/~wilde/swift3.tar.gz
>>>> I suspect it will take a while to narrow the cause to a simpler test
>>>> case thats easy tp reproduce without a lot of setup.
>>>> I'll try on a vanilla swift on local execution; this is on bgp with
>>>> Falkon.
>>>> Thanks.
>>>> Progress:  uninitialized:1 Selecting site:2
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 7
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 2
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 8
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 0
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 5
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 9
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 1
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 6
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 3
>>>> SwiftScript trace: T1af7, Round, 0, Sim, 4
>>>> Ex098
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
>>>>     at
>>>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
>>>>     at
>>>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:176)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:296)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:233)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:278)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:391)
>>>>     at
>>>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:329)
>>>>     at
>>>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
>>>>     at
>>>>     at
>>>>     at
>>>> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
>>>> Execution failed:
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> Ex098
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>>     at
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
