[Swift-devel] Swift user guide
Ben Clifford benc at hawaga.org.uk
Mon Mar 2 09:43:50 CST 2009
On Mon, 2 Mar 2009, Ian Foster wrote:
> Ben:
> The example I saw in the code had the input array (e.g., "a", in "foreach v in
> a") constructed elsewhere in the program, with a[0] = v1, a[1] = v2. That
> seemed particularly challenging.
You can have single assignment with an explicit list of array contents
like this:
a = [v1, v2];
That works in the present implementation in some, but not all, cases - it
depends on whethere the expressions v1 and v2 are primitive types like int
(in which case it does work, and has worked since before Swift was called
Swift) or if they are mapped to files (in which case it doesn't work in
the present implementation, but could be made to).
