[Swift-devel] Swift user guide
Ian Foster
foster at uchicago.edu
Mon Mar 2 07:09:38 CST 2009
Ben:
The example I saw in the code had the input array (e.g., "a", in
"foreach v in a") constructed elsewhere in the program, with a[0] =
v1, a[1] = v2. That seemed particularly challenging.
Ian.
On Mar 2, 2009, at 1:40 AM, Ben Clifford wrote:
> On Sun, 1 Mar 2009, Ian Foster wrote:
>> 2) Arrays: I gather from below that the size of an array is defined
>> by
>> assignments to it. This seems confusing and dangerous to me:
>> doesn't it
>> require a global analysis, which must ultimately be undecidable, to
>> determine
>> whether an array is closed?
> yes.
> They're a very unpleasant structure at the moment. As I've written in
> other mails in more depth, I'd prefer to see them behave as
> single-assignment structures constructued by something like looks
> similar
> to but slightly different to the present loop constructs, so that
> you'd
> say:
> array = foreach ....
> rather than
> foreach ... {
> array[i]=...
> There would be no requirement for this to actually execute as some
> atomic
> operation, and could happen over time interleaved with other tasks, as
> happens for foreach at the moment; but from a code analysis
> perspective,
> its much clearer when the array is closed - after the single statement
> that assigns to it has fully completed, like non-array variables.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090302/50a907e6/attachment.html>
