[Swift-devel] Swift user guide
Ian Foster foster at uchicago.edu
Sun Mar 1 23:25:11 CST 2009
Reading a recent email about "iterate" got me looking at the Swift
manual. This is looking very nice. I had a couple of comments:
1) "Conceptually, a parallel can be drawn between Swift mapped
variables and Java reference types. In both cases there is no
syntactic distinction between primitive types and mapped types or
reference types respectively. Additionally, the semantic distinction
is also kept to a minimum."
--> I don't think we should assume that readers know what a Java
reference type is. Most will not.
2) Arrays: I gather from below that the size of an array is defined by
assignments to it. This seems confusing and dangerous to me: doesn't
it require a global analysis, which must ultimately be undecidable, to
determine whether an array is closed?
Statements which deal with the array as a whole will often wait for
the array to be closed before executing (thus, a closed array is the
equivalent of a non-array type being assigned). However, a foreach
statement will apply its body to elements of an array as they become
known. It will not wait until the array is closed.
Consider this script:
file a[];
file b[];
foreach v,i in a {
   b[i] = p(v);
a[0] = r();
a[1] = s();
Initially, the foreach statement will have nothing to execute, as the
array a has not been assigned any values. The procedures r and s will
execute. As soon as either of them is finished, the corresponding
invocation of procedure p will occur. After both r and s have
completed, the array a will be closed since no other statements in the
script make an assignment toa.
3) In the following text, the (,index) is presumably meant to indicate
an optional element. But as you don't use a different font, or indeed
have indicated what conventions you are using, readers may not realize
that.
foreach statements have the general form:
foreach controlvariable (,index) in expression {
     statements
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090301/0a1d9912/attachment.html>
